So, I have decided to replace the crankshaft position sensor on my ‘92 500SL this Spring. I am anticipating that the head of the sensor may (will probably) snap off in the process, so I am planning for this now just in case.
I carry a selection of new/used spares in a roadside kit in the trunk, just in case a part goes south on me on a long journey. I’ve got a spare EZL, MAS, EHA, CPS, OVP, AFS pot, distributor caps + rotors, coil, poly v, belt tensioner, alternator regulator/bush kit etc; short of a support truck :grin
Given the reports of these crankshaft sensors snapping during removal, I figure that I would rather replace the sensor in my garage instead of on the open road.
So, the things I will have on stand by if I have to pull the sensor casing out: -
- dowel puller (with selection of adapters. In this case 8mm);
- 100mm x 4mm shank dia general purpose screw;
- 25mm long, 8mm dia x 1.5mm thick alum/steel tube or 6mm dia x 1mm thick (inside dia of tube needs to be big enough so that you can insert the screw);
- electric drill and 4mm drill bit (or to suit screw and tube size I am using);
- penetrating oil;
My method will be: -
1) Soak in penetrating oil 24hrs. Boiling water, then freeze spray. (Shock treatment). Try to wiggle the sensor out in one piece. Old sensor will go in my spare parts kit. New goes in car. If sensor snaps, I will carry on as follows: -
2) Drill pilot hole through end of sensor.
3) Insert screw into alum/steel tube.
4) Screw into sensor so that point side fully engages with steel end of sensor.
5) Dowel puller - Select adapter size to suit tube diameter. In this case 8mm. Place puller adapter over tube and tighten. Follow instructions with puller kit. Tightening the nut on the outer collar pulls on the 8mm tube, which bears against the head of the screw, which should extract the sensor housing.
Notes: - Make sure that the inside diameter of the outer collar of the puller kit is larger than the diameter of the sensor.
When drilling any pilot holes I normally try to make the pilot hole slightly smaller than screw. But with the guts still in the sensor there will be too much resistance to get sufficient embedment, resulting in just extracting the guts and leaving the sensor casing behind, so I will initially select a pilot drill size to match screw shank diameter I am using.
It will be trial and error, so if the guts come out, I will then select a slightly larger screw to ensure a tighter purchase between the screw thread and sensor casing and pull again.
You get the idea.
I doubt that a screw extractor would work satisfactorily. A screw extractor is tapered and would push outwards on the sensor casing, increasing the binding resistance between the sensor casing and transmission bell housing, and possibly also causing damage to the housing.
