M104 suspicious engine noise
3.6K views 24 replies 15 participants last post by  Maxbumpo
Hi everyone,
I post this message in this section, although my car is an R129. M104 is more common on W124, and I hope you can help me.
I've had a 1995 SL 280 for 5 years already, bought from someone who no longer drove it and didn't maintain it very well. I have been trying to "restore" it since, but I notice a noise more and more present, over the years. Before it only did it hot, but now cold too.
  • I note the presence of a slight click, varying according to the engine speed.
  • You can hear it more at idle and at low revs (beyond that, if the noise is still present, it is masked by the engine)
  • When cold, you don't hear much because of the air pump, but I would say that it is more present when hot.
  • It seems to come more from the lower part of the engine, I don't hear anything particular in the cylinder head.
  • The noise is gradually getting worse (nothing noticeable 4 years ago), and the oil changes don't really improve, I'm on 10w40.
  • In acceleration impossible to hear anything in particular, in deceleration on the other hand yes, since the engine makes less noise.
I made a video, which I hope will be more meaningful :
Do you have any ideas what it could be?
I plan to open the engine, but I would like to know where to look for the problem...
Thanks !
Thomas
Belt tensioner would be my guess. What's the mileage?
Put a stethoscope on all the moving bits on the engine, CAREFULLY, while idling. You should be able to isolate the ticking. Injectors, pulleys, pumps could all be suspects.
A primitive stethoscope could be a broom handle or screwdriver for a quick diagnosis.
#3 ·
Tensioner would have more of a squeak sound.
does the belt feel loose? You can take the belt off and rotate all the pulleys by hand to feel for a bad bearing Or something easily
it sounds like some mechanical like valvetrain or timing chain guide noise to me but it’s hard to tell on a video.
#4 ·
It may also me the aforementioned air pump bearing. My W124 cabrio made sounds like that before I replaced the bearing.
#5 ·
Maybe you can give us a video with the hood open. Whenever you are trying to diagnose a noise your first approach is to zero in on the noise. Maybe having the hood open we can determine if it’s from the front of the engine or back further. Could be a loose or failing bearing somewhere along the the belt drive or it could be a timing chain noise. Hard to tell.
#7 ·
First of all, thank you for your feedback.
The car has 100,000 miles.
For me, the noise does not come from the front of the engine, it is more audible in the lower part. (Nothing on the cylinder head side either). But I will still try disconnecting the accessory belt.
I'm going to try to put myself under the running engine, to listen to the stethoscope, and make you a video.
#8 ·
A rod knock would also fit with what you describe and what is heard in the video, but at 100K miles, that would be extremely unusual.
Reactions: 4Matic 300TE
#9 ·
As mentioned, I did some tests, with a stethoscope. It wasn't necessarily obvious but I still have a more pronounced knocking at the bottom crankcase/engine block on the last 4, 5 and 6 cylinders.
I also did the test by disconnecting the belt, it confirms that it does not come from there, since there is no change.
I'm afraid it's a connecting rod problem... :cautious: Although this engine is not known for that!
A new video turning around the engine :
#12 ·
I will be very surprised if it is a lifter problem. Sometimes I hear one knocking after a long stop, but it's just a few seconds while it reboots and it's not at all the same noise as it's now.
But I planned to remove the cover, to check my timing chain, it will be an opportunity to watch. ;)
Regarding the 5w40 oil, I had already tried it on my very first oil change, but I found the engine really noisy. So I switched to 10w40 and it seemed better. If I had to give it a try, I would tend to take a higher grade (15w50?)
#13 ·
After listening to your video, the noise it too high pitched for a rod knock. Look for a pin hole in the exhaust system near the motor or loose exhaust manifold bolts. If you can, smoke test the exhaust system as a pin hole that can make that sound can be tiny and hard to find.
Reactions: ianrandom
#18 · (Edited)
You can kinda check rod related like this guy, around 5min (he has other videos on his channel, including noise, in this video his 3rd cylinder moves down a bit, later he found worn bearing)
I also had some weird ticking noise (maybe similar to yours but I dont remember exactly now) and I was hearing it best from ouside around wheel arch and inside car when idling coming from footwell and there was more noise when shifting in drive and not moving, In the end I found something was shaking inside drivers engine mount. Mount wasn't old so I changed it again the noise was gone. It took me almost a week to find it. Stetoscope didn't really help as I could hear this ticking almost everywhere..
#19 ·
lifters.
my 2 cents.
@lowesguy has a decent post /thread - not too long ago - on his noise (m103) issue.
Review his thread for a reference - well documented.
#21 ·
Thanks for your feedback. The video of this Russian guy (as well as the others) is very interesting, luckily I'm not at that stage!
I also reviewed lowesguy's entire post.
I made a little progress on my side, doing an oil analysis. This brought out way too much lead and copper, so I have a bearing problem somewhere. (Connecting rod bearing on crankshaft? Connecting rod bearing on piston?)
Here is the detailed table that we obtain:
Also, by analyzing the soundtrack, I counted the number of knocks per minute, I get 354/min. That is twice less than the idle speed. It could be a lifter but I don't believe it. It could also be the explosion frequency in a cylinder, but I couldn't hear any improvement by deactivating the cylinders 1 by 1.
I don't see any other tests to do, except to take it apart to see inside...
#23 ·
Welcome.
If you're able to put your vehicle into your profile, it's a helpful thing for all 👍
#24 ·
I am having the same engine noise after performing a head gasket and oil pan gasket repair.
Did you ever find a solution or cause of this noise?
I didn’t have a tick upon first start after the head gasket repair. After 3 min the tick began.
Still trying to figure it out.
#25 ·
More than likely a hydraulic lifter tick. When Mobil 1 was full synthetic, it had some really good detergent properties, and it had a good reputation for clearing up sticky lifters and eliminating the noise. I don't know if that is true anymore, I suspect it probably is.
