Hi,
I suspect my headlight is not working properly as both low and high beam of the same bi-xenon is working ( as it light up without message from MDP) but extreme dim on both sides. In deed, it is useless and unsafe driving in the night.
Am I correct that the drl is using the low beam of bi- xenon? So is it possible that for some reason it stay at drl mode even at night?
I plan taking the light to my bench and hooking the power directly to the headlight to check whether it will be brighter if I could find the diagram or schematic of the waiting harness at the connector.
Attached pictures are in the order of:
Low beam, high beam with blocked H7 high beam, high beam with H7 high beam, low beam with fog light.
Slightly better luminus on the driver side after replacing a burned oem.
