Loud brake squeal, noise front brakes...
20K views 20 replies 10 participants last post by  MoroS550
Use coarse sandpaper or a grindstone to sand down the surface of the pads. Bevel the edges as you do so. Also give the rotors a sanding.
Otherwise, you seem to have done everything correctly. Just make sure the shims are correctly aligned, and do not use too much grease!
