Keyless Go not working on driver's side
19K views 10 replies 8 participants last post by  Tonya Pace
Hello All,
Hope all is well. For some reason, the KEYLESS GO lock/unlock black buttons recently stopped working on the driver's side of my vehicle. Interestingly however, the black buttons work on the passenger-side doors.
Any advice would be greatly appreciated.
Thanks so much!
Hello All,
Thanks so much!
Good afternoon. Ok so you can rule out the door lock actuator if the vehicle will still lock or unlock manually using the door switch or your remote. If it won’t lock that way I would say it’s the lock actuator. If not it could be the handle assembly with the button. Let us know what you find.
#3 ·
Thanks much for the advice. The door does lock/unlock with the remote. However, the black buttons don't work. Would greatly appreciate the help.
#7 ·
Very interesting. I have noticed that on my 2010, the black button on the door handle does not unlock/lock when the weather is warm but works when it is cold. I try with the button on the driver's door, when that does not respond I use the rear door (driver's side). The other two on the passenger's side work as well. Any ideas?
