Jump (rear) seat installation photos
28K views 32 replies 7 participants last post by  Candellara
Just recieved rear seats. MB Tex. Here are photos:
#3 ·
Cool,
I just did that recently and if you look in the owners manual you'll see your seat belts are reversed.
According to the manual the passenger sitting on left buckles it's seatbelt into the RIGHT passanger side buckle. Difficult to explain, but look the owner's manual and you'll understand.
Cheers
#4 · (Edited)
The hard part is getting the outer seat belt mounts bolted in. I had to remove my entire side panels, but I replaced the rear shocks at the same time, so I didn't mind.
I have a task list of what it takes to remove the side panels posted somewhere. (I'll plan on editing this post linking to that list.)
EDIT:
- Task list to replace the rear shocks (including the side panel removal): http://www.benzworld.org/forums/r-c107-sl-slc-class/1549113-ride-height-r107-9.html#post4644337
- Some pictures from my rear seat installation, at least the parts where I had questions: http://www.benzworld.org/forums/r-c107-sl-slc-class/1578083-folding-rear-seat-installation.html
#5 ·
Is there a kit available with headrest? I've considered doing this in my 450SL but was concerned about safety without headrests. Thoughts?
#6 ·
I've never seen one.
Folding seats have lower buckets, so maybe you'd need them less with folding seats.
Have you ever tried sitting in one of these? If you can get the front seat far enough forward to fit yourself in, you will find that you have to sit in the cannonball position. That made me realize that there's not exactly a lot of risk of things moving around much back there.
I'm sure there's a size person that could benefit from a headrest, but I'm not sure what size that would be. I'm squeezing my 4-year-old and two year old into identical child/booster seats with 5-point harnesses. I plan on continuing that as long as possible. I (too) am worried about the can of worm I'll open up when I let my 4 year old daughter sit in there with no booster seat for the first time (and I have no 3-point seat belt back there). So I don't even want to have her sit in there to determine where her head will be.
I'd hate to think that someone could really be driving behind me and forget to hit their brakes. It's not exactly the type of car you completely miss on the road. (My 450sl is much louder than a 560sl.)
Why can't we ride around in the back of pickup trucks anymore like we did when we were kids?
#8 · (Edited)
Is she sitting on the parcel shelf? If so, take note that the bucket seats sit several inches lower (not as if that would change everything).
EDIT:
I just added the pictures. Take note that the seat belt hole and that flat area at the back of the side panel are normally entirely covered by the parcel shelf.
Also:
Dig the sweet kid seats in the back. My son won't ride in the red one on the passenger side. He's got to be in the gray one. (If I hadn't already had these extra seats laying around from a neighbor giving them to us, I would have attempted to buy something better looking. Instead I recycle.)
EDIT#2
I forgot to mention the reason for my lack of embarrassment posting that picture of the gray seat in my car. I believe it is soon to be replaced with the red one pictured below. (Added pics). At least that's the deal that's been agreed upon anyway.
#10 ·
#12 ·
Breng:
I thought you had picked up a red set. Right?
The gray set I have I picked up on eBay for a good price considering it came with all the hardware, including the top clip (that I've not installed since it appears to require cutting the back wall carpet, and using rivets). My kid seats hold the seat up.
I picked up a can of red interior paint expecting to re color the leather, but another member bought the non-oem folding seats shown, and he was looking for tan. I found a tan set, and picked it up. It includes different hardware which is not nearly as comprehensive. No seat belt rings for the side panels, no bars to hold down the leather strap(s), no top clip (as it is designed for two straps instead). It does have seat belts, bolts, and a single leather strap that can be bolted to the soft top tray which will hold up the seat. I believe that's the original design of these aftermarket folding seats.
So I'm splitting the purchase of the tan seats with a guy that owns a 500sl AMG 5-speed. I'm pretty sure that since the tan seat is not oem, this gray seat is going into his parts pile for a full reconditioning. If it weren't for the gray carpet on the back, I'd think it might be easy. But that plus the dent, makes it a project.
I don't have the red seat yet, but have the tan, and the gray (obviously).
#14 ·
Old pictures I never uploaded of OEM folding seat parts
The clip that holds the seat back up. (JJProducts does not have this and uses a strap.)
The bumper that I believe gets installed on the rear wall. (Not sure about this.)
The seat belt grommets.
The seat belts.
Also, there is a bar that screws into the vertical metal in front of the seat onto which a strap (just like the JJProducts one) is attached. This is to hold down the seat when it is folded down.
#31 ·
Update on this. After trying many different lap belts i finally received some that fit perfectly. I'll post some pictures as i removed the rear quarter panel trims and fitted them at the weekend and they went in perfect. I also opted not to cut out the rear quarter panels for the belt to pass through as i want to be able to revert to standard no seat configuration if i wish to and the belts neatly run under the quarter panel trim. The belts are Securon 210C
#32 ·
If you revert to the parcel shelf, it will cover the oval holes in the side panels.
Without going through the panels, you might want to be concerned with tension on the belts causing the side panels to bend and crack. Could be a lot worse than just cutting out the perforated ovals.
