Is there an adjustment for Rear Wheel Toe
1 reading
4.3K views 3 replies 4 participants last post by  ianrandom
Took the car for an alignment today after replacing the upper control arms. THe machine was a hunter machine and the tech, though young, was aware of the spreader bar. That put me at ease somewhat. It was a Firestone Complete Auto Care place.
The rear wheel toe is slightly out. Left Rear is +0.13 deg and Right Rear is -0.22 deg. A total Toe of - 0.08 deg.
Tech said that there is no means to adjust the rear tow. Is that true? Or is there a way ?
I think the rear toe is usually adjusted via height adjustment. Factory height should give you correct toe.
For lowered cars, there are offset bushings for the control arm which I believe are for toe adjustment. They could be for camber but I think they're for toe.
Okay, was just looking at the manual, section 40-330. The offset bushings are for toe adjustment. Part number 1233520765.
#3 ·
Subframe Diff and control arm mounts are apparently the most common reasons for rear alignment being out of whack. If not prepared to pay for a fix, (other than understanding the need to rotate your tires) I’m not sure there’s much reason to have the rear alignment even checked.
