"F" = Fault.
This means that the Airbag module detected a circuit fault in SRS light located on the instrument cluster. The SRS bulb circuit is simple, in that on one side you have switched 12V power (active when the ignition switch is in positions 1, and 2), and the other side is grounded by the SRS module to turn the SRS light on. So, if the SRS light control wire has a short to ground, the light will be on all the time, regardless of any other SRS faults, and this condition will be detected, and flagged by the SRS module. Why this fault is not reported by ICarsoft is beyond me, but there is a fault code for it (B1476).
Check the status of other live data for the airbags, seatbelt tensioners, sensors etc. to make sure that there are no faults (F).
If so,
You need to locate the Airbag module (behind the ashtray in the center console)
With key in your pocket, remove the connector.
Insert the key and start the engine.
If the SRS light is still ON, then you have a wire shorted to ground.
If the SRS light goes OFF, you have a bad SRS module.
