How to raise the rear seat headrest ?
39K views 13 replies 9 participants last post by  Triple cranks
Do I have to pull it up or some kind of setting needed ? I have a person sit on the back but the headrest didn't goes up. If I pull it up manualy I can lower it by the botton in front of center dash board.
My car is 2004 S430 4Matic with ventilate seats. Please help me if you know. Thanks
#4 ·
I have an 04 S430 and if i want the rear headrests up i have to manually move them up. I think it was on the later models that they had motorized rear head rests. The button on the center console will still drop them from the raised position but if you want them back up again they need to be positioned manually. Hope this is helpful.
#6 ·
Mine is a MY2000, but they raise when I press the raise button on the dash. I press and hold for like 5 seconds. Also, whenever a rear seatbelt is fastened, the corresponding headrest raises.
(U.K spec car, so dunno if that makes a difference)
#10 ·
I just have to put my seat belt in and it comes up automatically.
I think I should add (don't want to insult anyones intelligence) the button on the centre console has TWO "directions" if you have to pictures on the one button. To lower them you press the top part of the button, to lower you press the lower part and hold for around 5 seconds.
However, some cars only have a one picture on the button, where (probably) its means it will only drop and not lift.
