I initially mistakenly placed my Speedo Error Post in the AMG Forum. Then when I discovered my mistake I added links in the W204 and W220 Forums hoping to get more subject matter experts. Sorry for the doubling up. I have now transferred the main post back here where it belongs.
Speedometer Error and Star Calibration?
Our W204 2008 C220 has had a significant speedo error since new. The speedo indicates 60 Km/h when the actual speed is 56 Km/h, an error of nearly 7%. The car is fitted with the OEM wheels and tyres, ie 205/55 R16 91V tyres as specified for the 16” wheels with 7” rims; 7J x 16 H2 ET 43.
All the experts I have asked state that it is mandatory for a manufacturer to make sure the indicated speed is always higher than the actual vehicle speed so that they are not liable for speeding fines.
IMHO 7% is too large a difference, (my W220 S500 agrees within 1%) so, with new tyres needed soon, I have been researching STAR and doing some speedometer calibration testing.
The issue is that to be travelling at a speed which doesn’t generate a speeding ticket or annoy other drivers, say 62 – 63 Km/h, in a 60 Km/h zone, the C220 has to be doing an indicated 67 Km/h. This makes using the best feature on a M-B vehicle, that is the Speed Limiter, a real pain, requiring multiple flicks of the steering column lever. The main increments are in decades, 50, 60, 70 etc. with single digit increments available via further setting. For example 67 Km/h is achieved by setting say 50, 60, 70, 69, 68 and then 67, ie six presses when only one or two should do. This issue also applies to the Cruise Control setting.
According to Star Diagnostics and WIS, the M-B measures the rotation speed of each wheel and then using a complicated formula, calculates the actual speed of the vehicle, taking into account straight line driving or turning around a corner, wheel spin due to snow, ice and mud, sensor failure etc. The four wheel signals are processed in the Traction Control Processor and the results used by the, ABS (Brakes), ETS (Traction Control) etc. WIS also states that the Instrument Cluster has a computer to further process the resulting speed signal, for parameters such as speedometer display, average speed, speed limiter, cruise control, and maximum speed setting.
I discovered that calibrating the speedo against a GPS is not easy as the GPS speed fluctuates a fair bit, however by using my Bluetooth ELM327 device which plugs into the OBDII port under the dash, I can monitor various car parameters on my Smart Phone using the Torque App and even record the data in a file for later analysis. Thus it is possible to record the OBD vehicle speed and the GPS speed while the vehicle is travelling at a constant speed set by the Speed Limiter. Then it is easy to average the measured results in a spread sheet to get more accurate values. For how to do this see my article at: Code Readers - W220 Encyclopedia
The results are interesting. First it seems that it is not possible to monitor the indicated speed shown on the Instrument Cluster using the OBDII port. The only available parameter is called OBD Speed and is not identical to the Instrument Cluster displayed speed. I suspect the OBD Speed is the result produced by the Traction Control Computer based on the signals from the four wheel sensors.
This is a summary of a couple of road tests I made with the Speed Limiter set to 60 Km/h.
Thus the four wheel sensor signals are combined to produce the 56.80 Km/h which is then processed in the IC to display 60 Km/h on the speedo. Note the 56.80 Km/h speed calculated by the vehicle is slightly faster than the actual speed of 56.23 Km/h which is as it should be due to the mandatory regulations. But what annoys me immensely is the displayed speed of 60 Km/h when the vehicle is only travelling at 56.23 Km/h.
Sorry for the long article but my question is: Is it possible using Star to provide a calibration or correction factor to make the displayed speed closer to the actual vehicle speed? I have checked through STAR WIS and the diagnostic sections, so far without any luck.
A small improvement may be available by changing the tyres from 205/55 R16 to 205/60 R16. This will have the effect of increasing the sidewall height by 10.6mm thus improving the displayed speed by 3.2%. I plan to thoroughly test this idea first by performing some more speed testing with the existing tyres deflated to about 15 psi and then inflated to 45 psi which notionally should change the rolling radius by about 15 to 20 mm.
As always any ideas much appreciated.
Brian
PS This was the Original Posting here in the W204 C-Class Forum:
I need help from the STAR experts to know if it is possible to change the indicated speed closer to the actual vehicle speed.
Please see my posting at:
http://www.benzworld.org/forums/w204-c63-amg/2384857-speedometer-error-star-calibration.html#post12294153
Regards,
Brian
IC Speedometer Indicated Speed = 60 Km/h.
Average (of over 4,000 readings) OBD Speed = 56.80 Km/h.
Average Actual GPS Speed = 56.23 Km/h.
Brian
Regards,
Brian
