head bolt torque specs
13K views 4 replies 2 participants last post by  Braunhilda
Hey all. I am putting together a 300TD engine (non-turbo) from a 1980 wagon and I'm wondering what the torque spec is for the 4 small head bolts--the 2 in the chain area and the 2 just outside it--the ones with the allen heads.
Thanks!
Braunhilda
1980 300TD
Hi Braunhilda
Here are some specs for you.
Nuts for cylinder head cover......15Nm or 11.06 foot pounds
Hex socket cyl head screws.......step one 70Nm or 51.62 Foot pounds
step two 90Nm or 66.38 Foot pounds
setting interval 10 min
step three 100Nm or 73.75 Foot pounds
Hex socket cylinder head screws
step one 40Nm or 29 Foot pounds
step two 70Nm or 51.62 Foot pounds
step three 90 degrees
step four 90 degrees
All of these settings are with engine cold!
Necked down screws for cam shaft sprocket 80Nm or 59.00 Foot pounds
Hope this helps.
Cheers
Big Dan :bowdown:
Vancouver Canada:thumbsup:
#3 ·
Thank you, but actually, I was wondering about the 4 smaller M8 bolts that use a 6mm hex socket/allen wrench to tighten. I assume they should be tightened after the (regular) head bolts but to what torque I can only speculate. Anyone have any info on this?
Thanks,
Braunhilda
1980 300TD
#4 ·
Those are 22 Ft pounds each.
Cheers
Big Dan:bowdown:
