Glow plug stage controller W204 C220 CDI
31K views 9 replies 5 participants last post by  nadgetastic
  1. I need to replace the glow plug stage controller for my merc c220 cdi W204 but I can’t locate it on my car.
#4 ·
Thanks Adrian I did manage to locate it and replaced it. I was having a caution mark appears smultaneously with the engine light and at that moment it loses power I have to switch off the engine and restart the car then only the engine light appears back and I regain my engine power.
After replacing I am still experiencing the same problem and I am getting advice to reset the car , how far true could this be. That glow plug stage controller was picked up to be faulty.
Please assist.....
#5 ·
Please assist.....
Hi Machismo,
First of all, if you have the same problems after you changed the relay you should use a tester ( Delphi or Mercedes dedicated STAR ) to read the erors codes. At this point I can't help you.
Try to read the errors code and post here to help you. After you read the errors try to clean them and see if the engine light come on again.
I'm curious how hard it was to change the relay? You had to take off the large aluminium piece from egr?
Good luck !
#8 ·
[QUOTE = "AdrianPav, hozzászólás: 17919897, tag: 1256813"]
Szia,
Az izzítógyertya relé az ábrán látható helyen található. Nehéz látni az üzemanyagcsövek és az egr.
A relét a szívó műanyag ház alá szerelik fel. Ahhoz, hogy hozzáférhessen hozzá, vegye le az egr -t, a nagy alumínium házat.
Meg tudnád mondani, hogy milyen hibád van?
[/IDÉZET]
