GL 450 rear suspension problem
4K views 6 replies 3 participants last post by  0to60in4.2
Hello everyone, my rear suspension dropped and I replaced air compressor, valve block, rear height sensors, air filter hose under passenger side fender. I am all out ideas. When I took my car to independent MB service he said right side height level sensor was bad. When I drove off from service parking lot rear went bad again. Do anybody have any idea what may cause this problem? all parts are replaced including relay!!!.
#4 ·
Then double check your level sensors, they can be put incorrectly, which confuses the airmatic module and will deflate the airbag because it thinks it's too high.
#5 ·
Now, car's front is risen, rear is flat. When I try to lower the car, it reads "Being lowered" but no action. I replaced battery and auxiliary battery too today. I'll check rear sensors which I used after market from eBay. Should I OEM only and so should I do anything else?
#6 ·
Post #5.
Double check your level sensor.
#7 ·
I recently went through same scenario - changed compressor, compressor block, rear airbags, height sensors. The problem was one of the rear height sensor beams was set wrong direction. The horizontal part needs to point toward the outside not inside. A scanner would show voltage out or range and/or height data at +5" so the computer lowers rear as low as possible. After this is corrected, you must use scanner tool to manually calibrate each wheel height to -1.2". After you do that you must set auto calibration which takes up to 10 mins. It will then store the proper ride heights.
