This has been discussed at length at What burns up a BCM? Battery Control Module - MBWorld.org Forums and Battery Control Module rebuild / replacing capacitors but I thought I'd make a new thread as the detail in the header above is easier to find on Google searches.
These fires appear to be a real threat, with many reported instances. Fusing the BCM should provide protection.
First, take the lid off your BCM and look for any burnt components. Mine was fine. They can start to burn up and still work, as you can read in the threads above.
Using information from those two threads, I fitted two fuses in the BCM:
Under the red heat shrink is an M6 nut and bolt which goes to the 30A fuse holder. There are two inputs on the BCM - circuit 30 and 30A. It's easy to see here how it all goes together.
Next I cut this door in the trim (I'll tidy it up later) so I can take the lid off the BCM and inspect it, as well as access the fuses. They should never need to be changed. I insulated the two lugs to the BCM here too.
All works perfectly. I would strongly recommend every owner investigate this mod, for a smoke-free drive. I'll report back if there are any issues but I cannot imagine the BCM drawing anything close to that sort of current in normal operation.
