Front center jack pad
1.6K views 7 replies 2 participants last post by  jpeter6981
The "circular" piece in the center of the pad pulls down (which will then allow you to push the pad into place on the frame) Then push the "circular" piece back up to lock it into place. Be careful though... it is pretty easy to break that center piece. Also, when reinstalling your protective covers... make sure they both fit properly under the tabs that are sticking out from either side of the pad, or, you will just break those off as well.
Hello Baron. This should be the part number you need: 002-998-06-50
There are all kinds of them on Ebay / Amazon / dealer sites (both MB and aftermarket)
