Front Bumper Cover removal,step by step.
1 reading
29K views 3 replies 2 participants last post by  rudeney
#1 · (Edited)
This is how to remove your front bumper cover for repairs or replacement.
1.Safely raise the front end. Remove wheels if you want good access.
2. Remove lower front fender liners and lower grills.
3. Remove the fender to bumper sandwich clamp by removing the bolt at the rear end and then pull /lever it out.
4.Disconnect the electrical connections to the fog lights and the temperature sensor.
5.There is no need to disconnect the fluid supply lines to the headlight washers as they are not mounted to the bumper cover.
6.Remove the 8mm mounting bolts (front facing ) near the fog lights.
7.Remove the 8mm mounting bolts ( up facing ) near the main grill. A magnet is helpful to retrieve them.
8.Remove the two screws from the grill top mount bracket.
9.Pull the bumper out and place it on the ground.
10. Remove clamp from Parktronic sensor harness and disconnect it.
11. The grill can be removed from the bumper cover simply by pushing plastic tabs aside and pulling it out.
Replacement is a reversal of the above, with attention to the adjusters located on each front fender.:thumbsup:
#4 · (Edited)
Good idea. Also, this removes the entire bumper cover "assembly". If you are needing to replace the painted "skin", then you have to disassemble the bumper assembly to remove all the grilles, fog lights, inner frame and energy absorbing pieces. I don't think there is a WIS doc for that - you just have to do it. It;s not too hard, but some of those plastic tabs can break, but for the ones on the skin which is being replaced, no worries.
And - added to "maintenance" stick thread.
