Background-
The car is a mid 2007 W211 E220CDI Saloon Facelift
Owned car over 3 years – never had any problems with it whatsoever
180k Miles on the clock
I service it myself- it gets serviced properly & on time
Today I drove the car to work – all good. Then at lunchtime I started the car up and immediately the red battery warning lamp came on along with all of the dash warning lamps. (As per the pics attached)
The car has also pretty much cut everything off- the ONLY things that
function now are-
Brake Lamps
Headlamps come on by themselves even if the switch is off
Wipers
Aux Fan inside
Engine.
Cooling fan runs mad fast all the time and the temp display is pegged at 85c outside. I wish- it’s about 12c in our Irish summer! Plus the fuel gauge and odometer are blank.
Pretty much everything else has totally stopped working. It’s like the car is in some sort of limp mode?
As for the battery this facelift car only has one – in the boot. I used a diagnostic scanner to read the voltages – they were 12.5 at rest and 14v at idle / running. No fault codes at all stored or current. I swapped this battery out with a known good one – voltages now 12.7 and 14v again. Car still the same with all the warning lamps on.
So with the battery ruled out and the alternator charging correctly where can I look for the problem? I have also pulled all Fuses in the car and none were blown. I have good knowledge of car electrics specially Mercedes w124’s! But these modern Benzes are a different story.
I don’t want to run to the dealer’s just yet – I am hoping you guys can give me a heads up on what to look for & test to correct this issue.
I have the original Battery on a CTEK charger now for 24hrs – just to be 100% sure the voltages are really high and try that again. Otherwise I’m guessing the Alternator or SAM module will be at fault unless there is some other device which reads the Battery Voltage & is faulty.
I would really appreciate some advice and if someone else experienced the problems above on a facelift w211 – what was the cure?
function now are-
Brake Lamps
Wipers
Aux Fan inside
Engine.
