Hello guys...have urgent question and I hope you can help me:
My S430 (2000) when you turn keys into ignition (when all lights start up) usually you see the gear position along the time at dashboard: PW 18:33 (clock). In this case, when I do that, sometimes the gear position goes missing and car can start and you can drive it (moving lever to D position) but you can't put back into R or P unless you pull over it and start it again. In ocasions when you move the gear from P to D, the selector at dash get stuck in PW.
Well, bottom line, after scann it, the failure says: ESM - Electronic Selector Module failure and part number to be replaced is: W220.267.3324
My question is:
Any ideas where to get the part? I was told it needs to be programmed? complicated?
Anyone knows where can I get the part asap?
Any ideas about how to fix the problem?
Thank you guys and looking forward.:wink
My question is:
