Error P0170 Fuel Trim Malfunction, (Bank 1) believe it's a MAF (Mass Airflow Sensor)
97K views 20 replies 14 participants last post by  RichardTK
Background
Hello fellow Mercedes enthusiastss. Quick background of myself I bought my first 1998 slk 230 in July. I love it and joined this site which has been extremely helpful
on pointing me in the right direction and avoiding those expensive dealerships. The following is my situation and my thoughts. A lot of the info I have taken from other
posts on the site and compiled it together. If some of you could confirm my thoughts or point me in a different direction it would be greatly appreciated. Wanted a little
feedback before I purchase the part and make the fix.
Symptoms and Error Codes
First my check engine light came on but car was running yet. I didn't notice any performance issues however that could also be from being a new owner. However one cold morning
the car would not start. It just kept turning over but not taking off. Like it was being denied fuel.
I pulled the codes P0170 Fuel Trim Malfunction, (Bank 1) which many posts point to the dreaded MAF (Mass Airflow Sensor) sensor failure.
Also code PO410 Secondary Air Injection System came up which I did not find any posts for.
What I have researched is that problems with Mass Air Flow sensors are common.
Bad or contaminated Mass Air Flow sensor can possibly cause a wide range of various vehicle drivability problems such as
- stalling, especially when the engine is cold,
- misfiring,
- poor acceleration, etc
Function of MAF Sensor
A MAF uses a measured temperature difference between two heated wires in the intake system to judge the speed of the incoming air.
(more airflow cools the wires more and signals the need for for fuel). In the Case of a bad MAF (which I think I have) it signals that less air is flowing past the wires
(perhaps they cool more slowly when they develop a film on them) then the volume of fuel injected for each combustion event will be less. So in general it is used to control
the rate of fuel flow at the injectors needed to burn at the correct fuel-air ratio with the mass of the air being passed through the MAF.
Conclusion
With error codes P0170 Fuel Trim (Bank 1) and PO410 Secondary Air Injection System coupled with it being a cold morning I believe the MAF (Mass Airflow Sensor) sensor failure
is at fault. P0170 Fuel Trim meaning that the MAF is telling the ECU to enrichen the engine and it's reached it's limit.
What happens at that point is other stuff starts acting weird too. I think that is why the PO410 Secodnary Air Injection System code was thrown.
Solutions - Clean or Replace
Sometimes cleaning the MAF may provide a temporary solution to the issue. However this is probably a better solution when noticing performance issues and a temporary solution for that.
If the MAF gets dirty a Can of CRC Mass Airflow sensor cleaner may do the trick.
- Remove the MAF, removed the sensor insert from the MAF (requires security torx) and spray the entire thing and the gold colored wire near the end until it is shiny new.
Recommended cleaners from posts to this site.
- CRC QD Electronic Cleaner
- CRC MAF cleaner
In my case since the car will not start I believe the best route is to replace the MAF. As we all know this is not a cheap part and it is highly recommended going with Bosch.
People have had issues when trying to go the cheap route here with another brand. What I found is in my case with 1998 SLK 203 I have the following engine.
- SLK230 Chassis 170.447 Liters 2.3 Cyl L4 Fuel Gas Eng. Num 111.973
All SLK320's and '98 and '99 SLK 230's have the Bosch removable insert. BOSCH Air Mass Meter B3130-70629 F 00C 2G2 025
The following site Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips is recommended on posts from this site and has a very good price on a Bosch MAF for $178 which it returned as a part for my make and model of car.
- Link
Your Parts Search Returned 1 Part(s)
Installation
I have not found any detailed docs on how to replace. So I would imagine it is not to bad of job. The MAF is always located in the intake stream between the manifold and the air filter.
What I have seen is to disconnect the battery while installing. Make sure it remains disconnected for 30 minutes. This will reset all of the computers.
It is also important to ensure there is no air leak, the seal has to be perfect, or else you will have problem. If someone could point me to some more detailed instructions or give me some
pointers that would be great.
Conclusion
Thanks for reading through my post and giving any feedback on my situation even if it is just to say I'm on the right track. I'm hoping when I'm done solving this problem it will be
a good post for future people to look at on how to solve this issue. I will also record my steps on how I resolved the issue when I get to that point.
In conclusion as I become more knowledgeable about my car I can help others like those of you who replied to my post.
Cheers!!!
Corey :)
Corey,
I applaud what you are doing. I'm going through a similar drill myself with the PO170 code. Will try the cleaning route first, but need to order the 5-point torx bit first. Benzworld is fantastic, with amazing, helpful info. I have searched the posts and found much useful info, but I think a current summary will be helpful to many in the future. Thanks.
--Larry C.
#3 ·
To be honest... it might be something other than the MAF sensor. I think with the MAF sensor you get 3 code errors.
Usually the P0170 (MAF sensor USUALLY) goes along with code P0136/P0303/P0243/P0300/P0304
See if any of those codes come up. If so, you might need to purchase a NEW maf sensor as opposed to cleaning it. The MAF sensor can only be cleaned 1 or 2 times before needed to be replaced (usually).
#4 ·
gakz,
Thanks for the info. I did also get error codes PO301, PO302, and PO303 - misfire detected in cylinders 1, 2, 3. Also PO300 - random/multiple cylinder misfire detected.
Thought this was a separate problem related to spark plugs. I've never cleaned the MAF sensor, and thought that might cure the PO170 problem. Sounds like I may need to spring for a new sensor.
--Larry C.
#6 ·
Since you said you did also receive those codes, get the MAF sensor. It should be less than 200$, DO NOT GET AN EBAY ONE.
That SHOULD solve all of the problems... possibly even the 0410 code, itd be worth it to get the MAF changed out ASAP though to find out.
#7 ·
Background
No need to disconnect the battery. It will NOT reset the ME (engine) computer if you disconnect the battery. All engine codes and adaptations are kept in non-volatile memory. The only thing you will reset is your BAS/ESP setup which you will have to resynch afterwards. The SLK is VERY sensitive to disconnecting/connecting the battery and the chances are good you'll end up with a fried instrument panel - search the stickies for descriptions of it.
The best bet is to just buy a cheap scanner to Harborfreigt and reset your codes after swapping the MAF. Alternatively, just start the car afterwards, let it idle for 10 - 15 minutes, then take it out on a GENTLE drive, no hard acceleration or high revving to give the computer a chance to re-adapt to the new MAF. A 10 to 20 mile drive will do the trick.
#8 ·
Restating Issue
P0170 Fuel Trim Malfunction (Bank 1), P0410 Secondary Air Injection System, Car will not start just turns over, seems like it is not getting fuel.
Hey Gang,
I checked into the P0410 code more and found the following info from posts on this site.
P0410 Secondary Air Injection System - Look at the cold start air injection system
A check valve under the Air Filter Box allows air to flow into your exhaust, failure of this valve can cause MAF & O2 Sensor problems (Codes I’m getting P0170 and P0410). I have also included a pic of where I believe this valve is located – CheckValve.jpg
- On US models this is used to heat up the O2 sensors and catalyst quickly after a cold start..... the supercharger delivers the air needed....normally-aspirated MB's have an air pump
- A check valve under the Air Filter Box allows air to flow into your exhaust.......failure of this valve can cause MAF & O2 Sensor problems
- A check of the connections to the controller under the front plastic engine cover is also worthwhile
- Valve replacement recommended at 50K miles, apparently these valves can rust through from exhaust heat due to malfunction, then you can get exhaust in the intake before the MAF
- Someone posted that the check valve was a MB recall item due to early failure.
Has anyone done this change with any success? Also does anyone have a part number, official name for this part and recommended provider to purchase from? I checked Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips like I did for the MAF and could not find any parts with name similar to check valve.
Autohaus Parts for 1998 Mercedes SLK 230
Search by Car System - Select Car System
Back to the MAF Sensor
I also found more information out about the MAF sensor. You can replace this with two methods. 1) You can replace the Bosch insert only (Pic MAFSensorDetached.jpg) or 2) the whole MAF including the tube. (Pic MAFSensorAttached.jpg)
According to Bazzle’s posts all the Bosch inserts appear to have the same part number. F 00C 2G2 025. Another post suggests MB Part Number on this is PBT-GF30. Make sure you are getting an authentic MB part and not a duplicate.
If you decide to go with only replacing the insert you will need to purchase an Air Mass Sensor Torx Bit to remove it. You can find this and the Mercedes Benz MAF Sensor Insert at the following link Mercedes Benz MAF Sensor Insert.
One post however comments that the only way you can be assured of buying the genuine article is to purchase the entire MAF assembly (not just the insert) from a reputable source, such as autohausaz.com like I listed in my first post on this thread.
Entire MAF Assembly Link
I still have not found any good steps on how to actually remove and clean or replace the MAF on a SLK 230. I did find some good instructions for SLK 320 thanks to Icdial.
MAF Removal and clean SLK 320 (V6) Thanks to Icdial Picasa Web Albums - Lance - SLK MAF Cleaning
Also here is a good thread about MAF Mass Air Flow Sensor that I got some of my info from. Thanks Bazzle for all of your contributions.
http://www.benzworld.org/forums/r170-slk-class/1244848-maf-ams-afm-etc.html
The following is a site that provides Technical Information on R170 SLK-Class SLK Home Page. I checked it for MAF replacement and part locations but did not have much luck. I found the following schematic on the forums with a part that looks like the complete MAF sensor called B2/5 Hot film mass air flow sensor. Is this the same sensor as the MAF sensor? http://www.benzworld.org/forums/att...ents/r170-slk-class/180640d1212125374-diagnostic-codes-self-adaption-me-sfi.jpg
Thoughts
Should I purchase both the MAF Sensor and Check valve? Try one before the other? I know this is a hit and miss. Anyone else experienced what I went though? Also as I said from my first post please add or correct things I have stated in this thread. I also want this to be a good reference for future users with MAF and Check valve issues. Once I get the solution I will report detailed steps of what I did to fix the error codes of P0170 Fuel Trim Malfunction, (Bank 1) and P0410 Secondary Air Injection System, car turns over and will not start. Like it is being denied fuel.
Thanks for the input.
Cheers
Corey
#9 ·
Restating Issue
Hey Gang,
Cheers
Corey
Hi, Corey.
I can't speak with experience to the MB air injection system, but if the car won't start it isn't the MAF. You can unplug it and the car will still start and run on base settings (heck,unplug it and see if it starts, if it does perhaps you have an unusual short in yours, but that would be very very rare). Fuel trim with the misfire codes tends to suggest it isn't the MAF, from what I understand the air injection system could account for the misfires.
Take care and enjoy the ride,
Greg
#16 ·
Did you try installing the sensor, or did you just buy it and put on your shelf? You can certainly drive without the MAF sensor plugged in and if you still get P0170 codes then it's probably just a vacuum leak. Actually, in the W203 forum, many P0170 codes are vacuum leaks, not MAF sensors.
#12 ·
I was also getting the P0170 code and P0300 series of misfire codes. No problems starting, no check engine light, but bogs under hard acceleration. Yesterday, I removed the MAF sensor. On my car, the screws holding the insert are T-20 6-point torx with center post. I had this screwdriver bit, so removed the insert. I sprayed the little U-shape wire liberally with CRC MAF Sensor Cleaner (amazingly, available in Palmer, Alaska!). Wiped with Q-tips. As clean as I could make it. Sprayed inside, etc. Today, I drove into Anchorage (about 120 miles round trip) and used the OBD-II reader when I got home. Still had the P0170 code, P0300 codes not showing up.
I guess this means getting a new MAF sensor. My SLK has over 83,000 miles on the original, so I can't complain. Need to decide on just the insert or whole sensor. The housing looks in good shape to me.
Thanks to all for contributions to these posts. I would have never tried this without all of the helpful information.
--Larry C
#14 ·
WOW! I was just reading this post, due to my C220 getting the famous P0170 code, and saw PALMER ALASKA!! I grew up in Palmer! Went to Palmer High.. As a matter of fact, my Parents STILL live in Palmer! Small world!:thumbsup:
#13 ·
i also have encountered this problem (p170) with some other code i forgot for my slk230. At first, it can't start, called in mechanic from benz for a checked and found out one part go failed (i don't know the name of the part but he said the magnetic of that parts not working so that it won't let the fuel go thru which located at the back of the car juz next to fuel filter). He juz knocked the part twice with a hammer, the car start and straightaway we go to benz service centre to replace the part, fuel filter, MAF( juz clean), oil filter, change oil and reset computer.
After the service, it was good for a week and big problem coming in, the car won't accelerate at normal, it juz slowly pick up the speed, it was very dangerous since there was cars approaching when i make the u-turn. starightaway go back to benz service centre to recheck, p170 pop up from the computer screen, the mechanic juz help me to reset and asked me to come back if problem exist.
after that, the problem come back again and again, after repaired (MAF changed, o2 sensor chenged). the problem still exist. And i heard not only my benz have this problem, other benz in my area oso come with this problem. the problem never solved for few years.
now i get used to it, whenever the engine light come out, i juz reset the computer.
anyone solve this problem let me know. thanks
#15 ·
doin12volt,
Enjoyed your post. We moved here 4 years ago after 16 years in Anchorage.
Temperature this morning is 26 below zero (Fahrenheit). Highs today of 10 below to 25 below, without wind chill. Don't think I'll put the top down.
Take care. --Larry C.
#17 ·
I have a 1996 e320. I just replaced the MAF with a new, but very cheap aftermarket and cleared the code. After about 20 miles, code 0170 reappeared, and the gas mileage, which was horrible just before the MAF went out (at least I think it went out), is still horrible, probably around 10 mpg or less.
Any thoughts?
#21 ·
As far as I can tell from many forums and my own frustration with some odd behaviour, the MAF really begins to show signs of failing after oil contamination and just "not working anymore" is rare.
Main culprit for oil contamination is the PCV system. I've only got experience with pre-facelift layout of the engine - I think the facelift models are slightly different - but essentially:
The side on the right looking into the engine bay (exhaust side) is the high-pressure side. There's a centrifugal oil separator that in theory condenses the oil vapour and allows it to run back into the sump, with a minimal amount passing to the intake just because nothing can be 100%. The obvious hoses are very obvious, two smaller hoses run near the exhaust and perish. First is a slightly larger bore hose that takes oil to the dipstick tube. If it's gone, you'll smell oil, might find oil traces.
The second is a 3mm vacuum pipe that goes to the supercharger from the breather on the cam cover. If that one perishes, the oil separator doesn't work correctly. I'm hedging what I'm saying in that I can't remember exactly what it does - I think it provides vacuum, as it also messes with the boost, but am happy to be corrected on that. Either way, it's easily overlooked and gets scorched by heat. I replaced mine with a slightly longer silicone hose routed over the top of the air intake pipe, but simply cable-tying the normal one away from the head/manifold should be sufficient.
On the other side we have the real problem area. The low-load side of the PCV system is the traditional PCV valve with two nozzles screwed into the cylinder head. The rubber pipework can break - it does go brittle and hard over time - but on mine for example, it hadn't broken, was just more rigid than when new. All seals were intact.
The spring loaded valve vents oil vapour into the engine directly, to be burned off. The nozzles, being very narrow bore, get clogged with carbon deposits and crap - particularly when oil is coming in through the intake due to the high-flow oil separator not working. That side failing - so crankcase vapour doesn't relieve pressure into the inlet manifold - seems to increase the pressure on the other side which as it's not at high RPM/lots of flow, just ends up gunged up with oil which gets into the intake.
Upshot of this is, before buying a MAF, check for oil in the intake (mine had a dribble of oil on the air filter, very easy to see), and if there's oil in the intake, clean the easily accessed oil separator and pipework, then prepare for fun & games getting to the PCV valve and pipework which is underneath the inlet manifold. On mine, the PCV valve looks usable but as cleaning the nozzles needs all the pipework removing anyway, I replaced the whole lot.
Ignored for too long things like cam cover gaskets will leak, ending up with problems like oil in the sparkplug pockets. The other telltale on my car was a little trace of oil around the filler cap - and my filler cap is a new one.
