E300 vs. E300 Blueefficiency vs. E350 (all 4-Matic)
5.5K views 15 replies 5 participants last post by  OldGreyBeast
Greetings to all in this section!
Went through the stickies and Gen. Info threads, but still stumped.
I'm looking at various 2013 E-Class models.
Pulled the datacard on two, and one is an E300 4-Matic and another is an E300 Blueefficiency 4-Matic.
I understand Blueefficiency has a few improvements for fuel efficiency, but I'm worried about reliability. I've read about start-stop technology (can it be turned off?), fancy alternator, and other parts that are more complex on an already complex vehicle.
Car Gurus shows the Blueefficiency model worth around $4000 more (the two cars are similar, actually the one without Blue Eff. actually has the premium sound).
I also like the E350's.
So my priorities are SAFETY > RELIABILITY > EASE OF SERVICE (I'm an advanced DIY'er) > FUEL EFFICENCY (last)
What are your thoughts?
Also, does anyone have a link or PDF of the options sheets for the 2013 E-Class for Canada?
A lot of dealers are advertizing "leather seats" and when I pull the data cards using VIN's it's the man-made stuff.
Does one or the other hold up better over time? Is the quality/feel noticeable?
#3 ·
You are not trying to start another diesel v/s gasser debate?
The truth is that most of the owners, once they drive good diesel - will never buy gasoline car anymore.
Best sample is W210, where originally in 1998 diesel option was the cheapest one and $15k cheaper than AMG model. Now take today's prices of E300DT and E55 AMG from those years.
The AMG models with ca 200k miles have the value of tires on them ;)
That said, "good diesel" become questionable term and the OM642 (?) engine you are considering is high-maintenance engine, with weak oil cooler seals, intake flaps that require cleaning before 200,000 miles and with complexity of the engine, it is top end DIY item.
When it comes to seats - I would not sweat it either way.
I actually prefer vinyl as it usually last 30 years with no problem, when leather will need few replacement in the time.
Lately MB makes combination when center of the seat is leather (for advertising purpose) and sides vinyl for long-lasting. Point is that even experts have hard time to tell the difference.
Good luck on your search.
#6 ·
Those are marketing names, so take them with a grain of salt.
I did hear that gasers can be bluefficient as well, but have never seen one.
The principle is, that beside more efficient engine, the cars have ECO stops, regenerative charging and few other gizmos.
When they help to gain minimal % on mpg- they are additional maintenance items.
Lot of drivers don't like ECO stops and shut the feature off.
#7 ·
Okay that's good if you can shut that off. The car I'm looking for according to the data card is an E300 4matic blue efficiency.
I like both diesels and gas engines they each have their pros and cons. Would never want to start anyting on here.
Sent from my SM-A520W using Tapatalk
#10 ·
I did plenty of Googling and did run across that article before. Thanks for that anyway.
I came to the conclusion that blue efficiency is a group of different Technologies that can be applied to both gas and Diesel.
Blutec is Diesel only.
The reason I started the thread is because I came across two vehicles nearly identical and the one with blue efficiency was about $4000 higher value according to CarGurus. They were actually selling for similar price so I wanted to know what's up.
Was the blue efficiency really that much more when buying new?
#12 ·
That makes sense.
I was comparing two E300 4-Matics, one with and one without Blueefficiency.
From what I understand now, Blueefficiency can come in gas and diesels:
From https://media.daimler.com/marsMedia...ns-package-of-measures-for-efficient-environmental-protection.xhtml?oid=9361730
erodynamics: controllable fan shutter behind the radiator
Energy management: on-demand control of the ancillary components
Alternator control: conversion of braking energy
ECO start/stop function: switches off the idling engine to save fuel
Cockpit display: information for energy-saving driving
#13 ·
When you use your car for commute- fuel savings are not your priority, but we often do sightseeing and it gets exciting, how much modulating your right foot can change fuel economy. After cold engine starts first mile with mpg in 20's later on it can get excited to see it climbing to 35mpg, 40 mpg and 50 mpg.
#14 · (Edited)
The average MPG on my 2010 E350 4Matic has been 22.78mpg, highest 26.6mpg, lowest 15.6mpg. That's over the course of 55 fuel ups, probably a 60:40 mix of highway and town driving. I've got 70k miles on the car. I've dealt with 2 oil leaks* (currently working on one of those in another thread here), the AC system drain getting clogged, and one power lock failure in the 25k miles I've owned the car. Nothing that would leave you on the side of the road, but it's definitely been more temperamental than the 2009 Toyota Yaris it replaced (one MAF sensor failure in 110k miles I owned that car was the only issue). Mostly fiddly stuff that seems due more to the complexity of the car than design flaws.
Basic maintenance on the E350 is really easy. Oil changes, spark plugs, that sort of thing are a snap. Other work that requires getting under the car can be a pain, since they're too low for ramps and it can be a bit of a pain to put the car on jack stands without risking damage to the body or undercarriage. Not a lot of room to work in the engine bay. I don't have a lot of experience with other modern cars so they may all be that way. My 87 W201 (300k+ miles) and 86 Nissan D21 (272k miles) are a ton easier to do major service on.
The only modern Mercedes diesel I have experience with was a 2015 GLK owned by a coworker. It was fine for the first 175k miles or so then became problematic, she spent several thousand dollars a year in repairs on it between the 175 and 215k mile marks. We don't work together anymore so I'm not sure if it has gotten any better. It left her stranded on the side of the road at least 2 times.
I'm a huge fan of the OM602 and OM617 but I don't know how much experience with those translates to the modern engines. More of an 80s man myself :p
* this has been corrected below, but it was in fact 1 oil leak and one coolant leak, not 2 oil leaks. More details in post #16.
