Driver's Heated Mirror Problems
24K views 9 replies 7 participants last post by  Chris McBrien
I haven't found a solution yet, but I am having the same problem. I replaced my driver's side mirror with a used (tested as good) mirror, the dimming works and the motor works, but the defrosting doesn't work at all. What I would recommend if you have time, is take off the mirror assembly, and test the power coming off the harness to make sure there isn't a break in the wiring. I'm assuming the voltage could range from 5v but it might be as much as 12v, it doesn't need that much power as the miniscule increase in temperature on the mirror will have a large effect on defrosting.
