Indeed as for mentioned.
And the dash cluster does lose a few pixels. But you can get those fixed.
Funnily enough, I got my CLK when it had about 82k on the clock and it's still as tight as a drum.
The only thing I had to deal with was a cracked gear box caseing.
I noticed the gear box area was wet with oil underneath the car when I had it jacked up to remove a heat shield (heat shields can work themselves loose and cause annoying rattles at certain revs!)
My guy a MB was quite surprised at this discovery and said that it may be the seals of the gear box caseing. Upon closer inspection, he discovered the caseing had a crack in it that may have been caused by a casting fault when the caseing was made. I believe this to be an isolated case.
He was kind enough to order a new caseing from Germany, take the guts out of the old caseing and re-install them into the new one. Not a job that I'd fancy. He's quite the doctor of mercedes!
