Hi,
We have a 2006 E350 with the 7-speed transmission (722.9) sealed transmission that needs to have the fluid changed.
I've been trying to find out how this could be done and I'm somewhat confused. Perhaps someone could help straighten me out. I've found a lot of information about the 5-speed (722.6) transmission but not much on the 7-speed transmission.
It sounds like all a dealer does is to drop the pan, replace the filter, and add whatever what was in the pan without doing anything to flush the torque converter. This doesn't seem like the right approach.
It seems like a reasonable approach would be to drop the pan, change the filter, and use the flush technique where a liter of fluid is pumped out and then replaced. Can this be done on the 722.9? Is there a dipstick option for that transmission?
If not, I discovered that Assenmacher has an adapter for adding transmission fluid to the 722.9 (or a kit that has the adapter and a hand pump). Would it be needed to replace the fluid?
As far as I can tell, the transmission needs to be at operating temp to check the level. It seems like this could be ascertained by using an external temp device.
Any comments or ideas?
Thanks,
Richard
Thanks,
Richard
