Car swinging from the rear when going over slight bump
2.8K views 6 replies 5 participants last post by  Cavalier
Hi all
Another issue with my (issueless!) s class.
Basically what happens is when i go over any sort of hump at normal speed the car seems to swing like it is loosing control from the rear end.
at first i thought this was due to the size of my alloys (19inch) so i replaced them with standard 17inch alloys, however this has not stopped the issue.
Just last week, i had the car MOTd and asked him to list absolutely everything that needs changing or looks on its way out. I got everything changed, from ball joints to track rod ends.
Unsure if there is any part that i am missing which is causing this issue.
can anyone advise:)
thanks
#3 ·
And the associated sway bar bushings.
These cars also have an unusually amount of rubber bushings in other rear wheel linkages that can rot out with age / use.
How many miles on the car?
Was the suspension work confined to the front, or was the back end worked on?
