Hello,
My car keeps turning-off while i'm driving, I've gone to multiple garages and electric shops but none of them seem to know what's the problem and they're all just guessing saying change this and change that. It's quite annoying.
About the turn-off:
The car is automatic (not manual).
I'm driving in my car just like a normal person and all of a sudden the RPM starts dropping to zero then going back up to 9 a couple of times afterwards it shuts down. It doesn't matter what the speed I'm driving at. If I noticed this drop in RPM and started hitting the gas it stays on until I remove my leg from the gas then it shuts down.
What I've tried/changed:
I've changed the idle control valve (tried two of them - now the car has a new one)
I've tried changing the Bosch mass air flow sensor (I changed it into a used one, this gave me the problem of pumping gas without pressing the gas pedal so I went back to my old one although I'd point out that car also shut down while driving with the used one)
I've changed the electric wires connecting the engine to the battery (also changed the fuel pump relay and overload relay)
I've tried changing the ignition control unit
After a while I've disconnected the wire connected to the idle control valve and that stops the car from shutting down but gave me trouble starting the car in the morning.
So I've disconnected another wire (I'm not entirely sure what it's for so any help in this would be appreciated)- The wire is circled in red
What's weird is that electric people say my problem is mechanic and mechanic people say it's electric.
If anyone has any experience dealing with this, it would help a lot
About the turn-off:
