c43 6 speed manual?
4.6K views 16 replies 9 participants last post by  AMSports
Ive been told by a couple people and magazines that in Europe you could get the c43 with a 6 speed manual. just wondering if its true. and where you might be able to find a transmisson.
Cheers.
Johnny
Hi Johnny
To the best of my knowledge I have never heard of a 6 speed manual in the UK. However it is very feasible that AMG may have supplied the odd bespoke C43 with a 6 speed manual as a special order, a bit like their Performance Studio offering on their current model range.
I guess anything is possible, money pending. It may be worth emailing AMG direct and asking the question, as they may be able to offer more insight, maybe even the manufacturer?
Good luck in your quest!
Nath
#7 ·
Heres what Ive got.
The AMG send me this reply
= AMG
Dear Sir,
thank you for your interest in our website and in Mercedes-AMG’s products.
We regret to inform you that there are no AMG's with manual transmission
and we cannot modify it.
Best regards
Mercedes-AMG GmbH
Daimlerstr. 1
71563 Affalterbach
Mercedes-AMG
Its kind of cheap...
#9 ·
the getrag 5 speed works with the M104s but i dont think m113s
#11 ·
190e 2.3 16v
#13 ·
Tis was a so-called 'dog-leg' gearbox with first gear left and down from neutral. This meant that the remaining 2nd, 3rd, 4th and 5th gear were in a simple H pattern allowing fast and easy selection. In contrast to most Mercedes cars 5th gear was not used as an overdrive but realy destined to reach the top speed. The gear ratio's were
1st.G - 4,08
2nd.G - 2,52
3rd.G - 1,77
4th.G - 1,26
5th.G - 1,00:1
Rev.G - 4,40.
Top speed at 7000RPM were 230km/h
#17 ·
I think you have to use a different driveshaft but other then that it should bolt up and work fine. You will need the manual C280 drivetrain & clutch (if you can find an aftermarket flywheel & clutch & pressureplate for the euro C280 stick then I would recommend using that. There also is a true W202 5speed from europe but its even more rare than the 300e trannies but it is the perfect swap b/c it is a true direct OEM swap but you have to import it, which is not easy.
