Blower motor will not turn off
31K views 11 replies 3 participants last post by  mrboca
On the way home last night the AC started to act funny: Blower was not responding to Auto. Seemed to have a mind of its own. both high and low seeds were running. When I got home the blower fan would not shut off, so at 1 in the AM I pulled the battery positive side and said see you in AM.
Checked the AC unit this am after reattaching battery and with no load on car codes seemed Normal 1,93: 2,82: 3,85: 4,85: 5,87: 6,143: 7,7: 8,91: 10, 5.5: 11, 2.5: 12, 3.6: 20, 3.2: 21, 44: 22, 0: 23, 62: 24, 13.5:
Error codes 1234 and 1235 cleared
Vents are blowing cold air Temp at center vent 55
Blower will not shut off replaced regulator resistor 2 weeks ago and all seemed fine. Have temporarily disconnected so fan won't run.
Ideas, help appreciated.
I think I found the answer: previous post from MrBOCA
Also I do not understand how it turns off with the ignition OFF and door opened. There is no relationship. The regulator is between the battery and the blower motor. The only control is from the climate control. So if the climate control blower control is not adjusting the speed, the regulator is either misconnected or the driver transistor is permanently turned on (burnt). In the latter case, the blower motor will not turn off as long as the battery is connected to the car. You need to remove the power connection to the blower regulator to prevent battery drain.
If the blower regulator is burnt out, ask them to send you a replacement.
Will try this route first
#7 ·
#12 ·
Please update your profile with your model and model year for your car, so people will know what type of system you have.
The newer ones have integrated heat shields on them, and also protective circuits (if from a reputable manufacturer).
Putting a cut-off switch is a bit overkill, if it is for this problem. You could just unplug the blower / regulator plug.
