Audio 10 pinout and 12 V
3.3K views 14 replies 3 participants last post by  nonosto
#1 · (Edited)
#11 ·
Thanks, mrboca, but I hate those things. Thankfully I can R&R a transmission even if I can’t crimp a connector or splice to save my life. In this case, I peel back the insulation from a harness wire, wrap new wire for the accessory then solder and tape.
I wish there was something like this that works in a 3-way junction without cutting the existing wire -
Sixto
98 E320 wagon 198K miles
#12 ·
Too much work :), especially if the connection is not mission-critical, and in-the-cabin :). I actually used the Harbor Freight ones, which makes life even easier (no spade connection, slide the cable in, and then the cable tip of the device, press, and you are done). I used these in various camera installations.
Quick Wire Splice Set, 11/18 And 14/18 Gauge, 50 Pc.
