AMG is the only auto co. utilizing the "integrated seatbelt design" (shoulder harness attached to top of seat only), in vehicles exceeding 500hp now (all CL & SL AMG vehicles).
Does anybody ever question the ability of an integrated seatbelt to perform in vehicles powerful enough to require 5-point safety harnesses per NHRA guidelines (<12sec 1/4 mile)?
Does anybody ever question the ability of the airbag's deccelerometer to function in these highly modified AMG vehicles? Or if AMG modified the base models' safety systems when making all other modifications?
I experienced a low-speed high-acceleration head on collision in a 2003 CL55 where both systems' design proved insufficient. The seat back bent forward by over 40-degrees without a scratch or bruise to my right shoulder and I incurred a 10-staple laceration to the back of my head against the moonroof. It started from an automatic downshift (another feature worth revisiting). The front of the CL55 was sheared off before any decceleration. A simple electro-mechanical push button sensor/over ride will tell the airbag deployment module that the vehicle is crumpling for a timely airbag deployment. Mercedes is now putting up a disgraceful fight. It's going to be an example of either poor engineering or real poor management/love for the all mighty dollar (since the same seats are used across all CL & SL's for over a decade now). The unbelted driver sustained a 10x14cm hemorrhage to his occipital scalp area.
If you're going to wreck in your CL or SL AMG, use the break before attempting to transmit impact energy to the other vehicle by using the gas. In this example both drivers braced on the accelerators from relatively low speeds. The CLK is a good example of the proper shoulder belt connection for the CL class. The SLK and SLR are good examples of what the SL class should be equipped with.
Mark Soliman
Mark Soliman
