Hi guys 'n' gals,
After hunting for what seems like forever, I finally lucked out and found the 190D 2.5 turbo of my dreams!!!
Straight up, it's a sweetheart of a car and an absolute JOY to drive but, like many others, I can't help but think a 5 speed would just be the icing on the cake.
I've done quite a bit of reading about the ins and outs and have most of the bits and pieces pulled together but I still had a couple of unresolved questions that I hoped people on the forum could help with and also thought it might not hurt to have another thread that brings together helpful advice and jnfo.
My main hiccup right now is deciding which 5 speed set up to grab from two parts cars close by. One is an 84 2.2 190D and the other is an 85 190E 2.3 8V. Also I'm still open to other trans options or conversions/ rebuilt tranmission people might have available.
As far as the ratios, from what I can gather...
The 190D 2.2 diesels have:
4.23, 2.36, 1.49, 1.00, 0.84
3.42 final drive ...
The 190E 2.3 8V's have:
3.91, 2.17, 1.37, 1.00, 0.78
3.27 final drive (up to Aug. '89)
3.91, 2.17, 1.37, 1.00, 0.81
3.42 final drive (from Sept. '89 on) ...
And the Euro 5 speed 190D 2.5 turbos have:
3.86, 2.18, 1.38, 1.00, 0.75
3.46 final drive.
I'm sure either transmission would work and it looks like the 190E transmission with a 2.2 190D rear would give almost an identical setup as the stock euro 5 speed ... BUT ... I'd ideally like to have a LSD in the car and hoped to swap a 3.27 (or euro 3.07) 16V rear end at the same time as the 5 speed.
So here are the questions I've been battling with ...
In general what would people recommend between the two trans options (I can grab the diesel flywheel either way
) and what relative differences are there between them?
Would the gear ratio and spacing differences between the two trans options have performance differences? How would either pair with the 3.27 LSD? What about to the 3.46 190D 2,2 rear or the euro 3.07LSD?
Do the euro 5 speed stock ratios represent the ideal set up?
What combinations might still give a good balance between taking off and cruising the highways but still lean a towards the sportier side (with engine/power upgrades in mind)?
Any aid or advice would greatly be appreciated
and hopefully this thread will help others like me wrap their heads around what swap options might best suit their own 190D turbos. Thanks!
3.46 final drive.
