722.9 Transmission Revision. Just learned something new.
460 views 2 replies 3 participants last post by  Aweber
Which most of you probably know, but the revision requires blue fluid, while the original red. If you car was made after June 2010 it is probably the revised unit, called the 722.9 Plus. Among other things it has a larger capacity pan (with larger dimples) and a different filter. But have different internals too to require a different ATF.
