So ever since I got the car, it's been shifting kinda funny. Shifted flawlessly (and I mean flawless) during test drive and the first drive home. Then after that, it started slipping a little, then idling funny, then slipping more often, then shifting rough, then slipping more and more.
Last night I went out for a cruise with a friend and it slipped every other time I floored it. Then I guess she went into limp mode and stayed in either 2nd or 3rd gear, but I think it was 2nd. Whenever I drove from a stand still (just normal acceleration), it would start in 1st, then shift rough into 2nd, and stay there. Yes, the cats were already warmed up (I know about all that). Then I went for a few top speed runs. Whenever it shifted, it sounded funny (almost slipping I guess). After the runs, on the way home, I could not floor it as it would slip every time and hit the rev limiter. She was in limp mode the whole way home after that.
I had the transmission fluid changed (but I guess not the filter) a few days after I bought it. I'm not sure what fluid they used, just says "Mercedes trans. service" on one line, then "Synthetic trans. fluid" on the next.
I can't stress enough the fact that she always shifts poorly from 1st to 2nd or 2nd to 3rd. Kind of like in a standard, if you were shifting from 2nd to 3rd, but you kept your foot on the gas while clutching, so the engine would start to rev higher but then you let go of the clutch immediately and let it engage the next gear. Not sure what you would call this.
So I need to get to the bottom of this before it gets worse. I have no dash lights on at all (except exterior lights and today my windshield wiper fluid light came on briefly as I used a lot of it up washing the bugs off my windshield). So what's wrong here? Do I need a rebuild? New transmission? Hopefully this is not the case but I'm willing to put my money on it and this would mean I'd have to sell the car as I can't afford a rebuild right now. Otherwise she has been such a wonderful car.
Another small question: what would a 1992 600SEL's top speed be with the limiter? I don't think my car was ever delimited but I last night I got up to 261 km/h on the speedo and was at about 5250 rpm (so I had 750 rpm left). I have the 4 speed tranny of course. I thought they were limited at 250~255 km/h? But I definitely went over that.
Anyways, thanks in advance everyone.
EDIT: I also want to point out that ever since I got the car, the idle has been getting rougher. Seems like it's following the same pattern as the transmission. Now, once in a while (seemingly whenever the transmission also wants to act up), the idle at a stop light will change between 550 and 700 rpm up and down every half second. If i'm on the brake lightly, the car moves forward at that rate (very slowly). Reverse is the same, but it happens when I'm actually moving in reverse (idles up and down up and down). Not sure if this would be related, but it's worth mentioning, since it seems the idle acts up when the transmission decides to.
Hopefully someone can come on here and say they've had a very similar situation and know what a potential solution is or to guide me in the right direction.
