560SL Lighted Window Switch?
1.9K views 2 replies 3 participants last post by  strife2
After taking apart my center console for radio work a few days ago, I decided to look into some replacement window switches for my 560SL. (The old ones are working, but the labels are badly worn and look unsightly.) I've searched extensively, but all the aftermarket switches I can find are non-illuminated. Does anyone know a source for genuine OEM (or factory-correct) reproductions of these switches -- with lights inside the switch?
Thanks...
parts.com has OEM...a bit pricey.
Part Number 0008208410
Part Name SWITCH,WINDO
MSRP $114.00
Core $0.00
Save $32.40
Online Price $81.60
I ordered the Febi switches from AutohauzAZ about 4 years ago...they do (at least mine do) illuminate. About 10 bucks each.
1268208110 Power Window Switch; Front Left Window in Center Console
1268208010 Power Window Switch; Front Right Window in Center Console
#3 ·
If originality is not critical to you, I would look at a posting that I made on the "other" website some time ago, using W201 switches with a tiny wiring change. These switches are "double shot molded" with the legends built into the plastic itself, and not a polycarbonate label that will wear off. IMO, they also look better than the original switches. I built LED's into mine but this is not really needed.
If you don't want to change the wiring, the switch caps themselves are interchangeable so you can use an old cap on a new switch (there MAY be some subtle differences in how they are lit).
DO YOU BELIEVE the prices on the OEM MB switches?????????????????????????
