Head gasket
price is ok, genadswali
but the brabus engines are very delicate because of the big bore:
And iwhen you get problems with the cylinder head gasket
- you can take only brabus - which costs about 800€
and problems are preprogrammed!
Hi again :thumbsup:
I had never had any problems like I said with the big bore of this brabus.
But I had to get to the bottom of an oil cunsuming problem of my engine
So I toke it apart and found all the 2nd pistons rings to be broken into about 10-15 pieces on ALL 6 pistons, but all the other pistons rings were fine, so there was nothing to see on the compresion test.
But anyway I was wondering what could have caused this 2nd pistons rings falure
leaving the oil hanging on the cylinder wall upon piston movements, again leaving the oil to be burned away under detonation.
But the pison rings lands was also realy bad on the Kolben Schmith pistons that brabus used at the time.
So I had to go with new pitons and raise the engine bore a bit.
But sp far the original engine bore at 92,25mm wich is the original bore has been no problem at all, but I think that the piston ring falure was due to the former owner using low octane fuels that made the engine knocking, damaging the pistons rings.
So did the whole thing, new engine bore at 92,35mm the stroke is measured to 90,00mm and I had no other visual problems in the engine at all else.
The cylinder wall was acturely also very finde but looked like rehoned at some point, maybee becuase the piton rings had been changed once before but with bad piston ring land they ofcause will brake again.
My theory at least.
So I have now the Rebored M103 Block brabus used for the M104 3.6-24 to 92,35mm. and redone the head with new valve seats and all the other work usual done at the engineer shop.
I ordered forged JE pistons with forged performance H conrods as I also see the standart mercedes rods to be very heavy for the rpm´s and the long stroke this angine has.
So the engine could defently need all the help in the world to make the rotating mass lighter.
But to my main question.
What head gasket to use with this brabus engine M104.980
I know brabus make them if you drop 800Euro but thats insane
The former dealer that had to change the head gakset and rings at some point told me that he just went to use an AMG head gasket with the same 92mm. diameter, and I have measured this old head gasket and it IS realy 92mm. but could this realy be a AMG head gasket then
becuase this is far more cheap than bying the brabus one with the preprogrammed problems :surrender:
I was informed by Mercedes here that deals with brabus that the order number for the brabus 3.6-24 Valve head gasket is 00062444 I gues that is the brabus order number
What to do here, please advice :bowdown:
