2008 R350 4matic *NO CRANK NO START*
2 reading
9.3K views 5 replies 5 participants last post by  ianrandom
HELLO there, i have a 2008 MB r350 4matic 3.5 145k miles, issue I'm having with it is after a decent drive around town, if i shut the car off it wont start back up or even attempt to crank, key just turns, can hear the fuel pump know its not that. after the car sits for a little while it will start right back up again. has full power don't believe it to be as simple as a battery issue. runs excellent when running, brought it to my mechanic he said the ECU might be bad. got quoted 1300$ for a brand new one with programming. is it common for the ECU's to go bad? or could i be looking at a totally different issue? Car only has one code getting thrown p2088 for a camshaft position sensor actuator. which I don't think would cause a random no start no crank. any input would be helpful & much appreciated
Welcome to BW typeofway401,
Good to have you as a new member.
To realize the full benefit of this forum, please complete your user CP profile
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
ADD your make model YEAR ----> click save.
NO crank No start means, the ignition does not turn over when you turn you key to position 3, to start the car.
Are you saying this is the case?
Because your explanation says both
Or do you mean, it cranks but but will not start?
Check your battery voltage at the terminals. Anything less than 12.4V is a dead battery.
Test your voltage with the car running - should be between 13.7-14.7V
symptoms =====> starts up when cold====>runs fine
===> when hit ====> no start = cps fault
most likely you need to replace your CPS.
( which equates to your p0288 code)
Replace, test drive it and then scan again, erase any saved codes.
Monitor.
Moving you over to the w251 forum.
#3 ·
car will only give me the issue after it gets to operating temperature. So when the car is warm if i shut it off it will not start back up, i turn key to position 3 and nothing happens, doesn't crank doesn't start. only code I'm getting is a (P2088) A Camshaft Position Actuator Control Circuit Low Bank 1b. should i start by replacing that senor? or could it be a Bad or failing ECU like my mechanic said it could be? After the car sits for awhile it'll finally start right up. gives absolutely no issues at all when running.
