OK, I've had this issue several times, the last time was resolved with a replacement battery in the fob. Now I can press the fob and see the red light flash but no action on the locks. I can pull the key out of the fob and manually unlock the door, start the car and turn it off, exit and press lock and it does so. Could this be the #7 or 8 fuse that I've seen referenced for this problem? I can't understand how it will work sometimes and not others... either the fuse is blown and it won't work or it is good. Anybody have a go around with this one?
