2001 SLK320 starts and immediately stalls - No OBDII codes
315 views 5 replies 3 participants last post by  SLK320i
I have had my 2001 SLK320 for about eight years. It recently had an oil leak and I cleaned the engine and added dye to find it. It turned out to be the gasket/seal in the oil pressure testing port (just below the oil filter housing. I installed the new rubber gasket/seal and a new Al crush washer.
Now the car starts and immediately stalls. I tried disconnecting the battery for a couple of hours and reconnecting, no change. I can start the car as many times as I please but it immediately dies. I can rev the engine very briefly after the engine starts, but it still dies within a second or two.
For the last several months prior to this issue, the car has been cranking longer (3-4 seconds?) before starting up, especially if it had been sitting for a few hours or overnight. There are no codes showing with OBDII reader. I have a bootleg STAR diagnostic computer with attachments, which I have used on my other MB cars, but the R170 is not listed in the software so I am unable to use it for my SLK320.
I replaced the plugs with Iridium NGK plugs when I bought the car and also replaced the fuel filter. The car had 133K miles when I bought it and now has about 195K.
I love this car and am really hoping someone can give me some suggestions to diagnose this issue. I would rather not just start replacing parts randomly.
Thank you!
#4 ·
I have had the same issue with my 01 320. I spent a lot of time working on this but I got lucky when I found the k40 relay module issue. The vehicle stalled out and this was a factory issue. It’s a simple soldering job. you can find all the information on YouTube.
this is how to fix it
on the 320 like ours will find it on the passenger side next to the battery in the fuse main box
