Inspection at 800-1000 miles
Lubrication Service every 7,500 miles or twice a year (spring & fall)
Maintenance Service every 15,000 miles or two years
Additional Work every 30,000 miles
MB suggested replacing oil and filter every 3750 miles for "hard and sporty" driving
Auto trans fluid change every 15,000 miles, filter and fluid at 30K intervals
Brake fluid annually, preferably in the spring.
Coolant change at least every 3 years.
Lube engine throttle, linkage rods and shafts every 7,500 or twice a year (thats a lot of grease!)
Cats might need replacement after 50K miles
Every 15K: oil/filter, new plugs, lube throttle parts, door hinges, door locks and hood. Check fluid levels, inspect everything else for wear and tear.
Every 30K: oil/filter, air filter, check V-belt, replace O2 sensor, replace plugs, check clutch, flex discs
Every 60K: Replace fuel filter
Once a year: Replace brake fluid, clean water drains, clean and lube sunroof rails and sliding blocks
"Additional Work"
30,000 Miles / 4 Years
At approx. every 30,000 mi/48,000 km or 4 years:
Check condition of drive shaft flex discs.
45,000 Miles / 2 Years
At approx. every 45,000 mi/72,000 km or 2 years:
Replace recirculated air filter (if fitted).
Replace activated charcoal prefilter (dust filter, if fitted).
60,000 Miles / 4 Years
At approx. every 60,000 mi/96.000 km or 4 years:
Replace fuel filter.
Replace air cleaner filter element.
Replace spark plugs.
75,000 Miles / 4 Years
At approx. every 75,000 mi/120,000 km or 4 years:
Replace activated charcoal filter.
2 Years
Replace brake fluid.
Check body for paint damage (by Service Advisor).
Check chassis and supporting body parts for damage and corrosion (by Service Advisor).
3 Years
Replace coolant.
Sliding/pop-up roof: clean and grease sliding rails and sliders.
