1983 300D Manual Transmission Conversion
30K views 20 replies 11 participants last post by  FratBoy
I sourced the 39lb. 300D manual flywheel on Ebay. It wasn’t cheap at $1000.00 but it’s one of the keys to having a smooth running car with the manual. I’d read posts where the where the 240D flywheel was used and they generally talked about vibration.
Not in my experience. I have used a 240 flywheel for 13 years and my friend has used one for 20 years. ZERO issues with using the 240 flywheel. Its plenty heavy for smooth idle.
The important thing is BALANCE. These are externally balanced engines, the flywheel MUST be balanced to the auto flywheel.
I read that a 240 automatic crossmember would fit but it was way off.
Nope. Its what I use and it is a perfect fit for both the iron and aluminum transmissions.
The bolt receivers must be moved to the correct tab holes in the chassis.
I used the speedometer cable from the donor car as the ends on the cable for the automatic don’t fit the manual transmission. It is slightly longer but not a material difference.
They are actually the same. The only difference besides length is a flat driver end on the older transmissions.
The crank modification might be a little beyond the weekend mechanic
As a note, that only applies to 84+ engines. 81-late83 fit a normal pilot.
I couldn't agree more on the balance issue. Key is to have same for same go back into the engine. I can state that both my automatic flywheel or flex plate mount was very near neutral (within a couple grams), same for the heavy flywheel.
Right, but even a few grams at 4800rpm is a lot of force for the main bearings to absorb.
I actually ordered the 240D automatic part by MB part number. When it arrived the bolt spacing and span was identical to the 300D automatic part with the transmission mount in a slightly forward location but nowhere near enough. May have got the wrong part.
The one I have is 1232420701. It was pure luck there was an auto 240D in a pick-n-pull on the way to getting my 240D parts car.
Which transmission did you use? I like the Getrag the best so far. The slope-back was a bit more durable and my current flat-back grinds into every gear too easily if I want to shift quickly.
No, a 240D auto driveshaft will not fit anything but a 240D auto.
If you start with a 240D manual driveshaft, remove 4".
In addition, different models had different driveshaft center support mounting locations. That is a welded part of the chassis that can't be relocated.
For example, the entire driveshaft for a 280E 5-speed and 300D 5-speed is the correct length, but the center mount is in a different location, so one is useless for the other.
300D auto US A1234105801
240D auto US A1234108101
300D 4-speed manual A1234104701
300D 5-speed manual A1234108501
280E 4-speed manual A1234105301
280E 5-speed manual A1234107701
Reactions: gatorblue92
