Thanks for the reply! That was really helpful.
The listing "says":
-oil changes yearly
-recent coolant flush, valve cover gaskets, idler arm, front end alignment, brake pads
-never in an accident
-never driven in winter
-recall work done in 2017
-original R-12 air conditioning system and compressor works
-zero rust
-new tires
Like I said, I don't know much about cars, but for a 40+ year old car, this sounds like great condition? I don't mind paying when things go wrong, since I'm planning on having the car a really long time. I was just wondering if I were to get one that has had recent repairs done and is in "great condition"... if I'd still be paying thousands for maintenance?
It's certainly better to get a classic car from an enthusiast, especially if it was regularly driven and has evidence of work done recently. "Garage queens" aka cars that just sit around and are driven sparingly have a lot of different issues.
For what it's worth, my car was listed too as in, "great condition, everything works, mountain of receipts from the MB dealer, and a rebuilt engine". The reality of this was quite different once I got under and started looking around. The engine had several intake leaks because of sloppy work done by the dealer, the CV joints were cracking because of tired suspension components, and various other issues.
Absolutely get a pre-purchase inspection done at one of those euro shops you mentioned. Ask them if they're familiar with this vintage of automobile, make sure the subframe has been reinforced (check for receipts), and see what else needs done. I'd also have the shop run a smoke test on the top end. Any leaks, get an estimate for repair and use that in your negotiations or walk away from the car. A leak in the intake system is a serious issue and can require a lot of hard work to get it right.
And if there is any sign of rust, walk away. Rust is a silent cancer for these cars.
My dad is in his early 40's, I don't want you to think I'd be making my poor old dad do hard car work. I know he'd probably end up enjoying it, especially if I did it with him, lol. He built houses for 25 years, he gets bored now that he's just a superintendent.
To be fair, car work is never "easy" nor quick. It's physically exhausting work on par with construction.
I would run it past him to see if he's
really comfortable doing free car work.
I'm well seasoned and have mucked around long enough to get these jobs done quickly, but the reality is that an oil change is a hour long affair, a tune-up (replacing 8 spark plugs, wires, cap, and rotor) is 2 hours going slowly to ensure spark plugs don't cross thread, and fluid/filter changes (transmission, power steering) are typically in the 1-3 hour range . Triple these times if it's your first time doing it because a screw up will make an epic sad face.
Rebuilding the intake system, dropping the steering box, refreshing suspension components, CV axle replacements are multi-day long projects. Also remember that shipping for most parts comes from a few select warehouses scattered around the country. So if you need something budget in at least 3-5 business days to get something. Even longer if you need a really special part from the Fatherland (Germany) which can take 1-2 weeks or worse.
I'm 30 and started wrenching recreationally (that's a laugh) when I turned 19. It's a lot like going to the gym. It sucks, you'll hate it, curse in a new language, and wonder WTF is wrong with you.
However, just like the gym, you'll feel immensely satisfied when it's all done.
Using my skills I learned on my 300D, I was able to better troubleshoot issues on my later model cars (Saab, Prius, Mini) which will help you save money when you go to a mechanic. If you can spell out what is exactly wrong, you save shop time having the mechanic figure it out.
If you want inspiration, there is a user on Peachparts that goes by the name BodhiBenz. She learned how to weld and do body repair to fix her childhood family car and still drives it on the east coast. You can PM me and i'd be happy to make an introduction to her on FB.
Since you are now fully versed in what you're getting yourself into...
Welcome to the asylum!
