DRNITRO
Auxiliary battery dead, I think the auxiliary battery is in the 2003-2007?. Auxiliary battery located under cabin air filter on passenger side of car under the hood, one black plastic 10MM nut, all battery bolts and nuts are 10 MM.
Remove, Take to Walmart exchange core for 10L A2 motorcycle battery $45.
Cut off red and black terminal caps to height of new terminals, vice grips in vice to hold plastic caps, cut with hacksaw.
Put red cap over (+) terminal and attach to battery. Leave (-) terminal disconnected.
Drill small hole in side of battery case and pass vent tube through the hole, seal with silicone if necessary.
Remove - battery cable from main battery in trunk.
Let car sit for awhile, I did one hour.
Connect (-)wire on auxiliary battery, let sit, I did 10 min.
Connect (-) cable on battery in trunk.
SRS only malfunction when I started car, drove car 1/4 mile turned steering wheel lock to lock 4 times and SRS reset, I read that you had to do it 5 times
