I started the car today and got the message “Electric consumers offline!”. I assume that is the result of having left the car doors open for four straight days while I was working on another issue. The consumer battery is low on charge.
After reading a lot of threads here, I believe that I can either drive the car for 20-30 minutes and see if the message clears, or remove the consumer battery in the trunk, have it tested and replaced if necessary.
Then after reconnecting the battery, with the engine running, hold both window switches in the “up” position until the message clears.
Question #1: Am I correct so far?
Question #2: Maybe this should be a separate thread, but once the battery is reinstalled and reconnected, can I connect either a Ctek or BatteryTender brand battery maintainer to the battery posts without hurting any of the electronics?
Thanks in advance.
Thanks in advance.
