No, STAR works a bit differently than most OBD II readers. It does not just show a code. The first thing you will do, after getting STAR completely set up and running properly, is run a QUICK CHECK of all the control units in the car. It will list each control unit and show either a check mark for pass, no codes. or an -F- for Fail, codes present.
After the Quick Test you can click on a control unit that shows an -F- and STAR will take you to that particular units page. On that page will be a menu, one of the menu items will be FAULT CODES. Clicking on that will generate a list of all fault codes for that unit. They will be 2 types, STORED, meaning it happened before and either was repaired or reset it self. Or it will say CURRENT, meaning that fault is still present. The faults, both STORED and CURRENT will have the code listed as well as a short description of the problem.
For instance, during the Quick Test, your Navigation Unit shows an -F- . Selecting that, then FAULT CODES you find a code D011 shown. STAR also shows that as "The supply voltage of the control unit is too high"
The above is a much simplified description of what STAR can do, but I hope it will at least answer your question.
