airmatic epoxy fix documentation
I'm back. The videos have been replaced by a pdf document - 1st doc attached "SUMMARY OF EPOXY FIX..." Hope it is more useful, allowing for quick review, printing, etc, which is more difficult with the videos.
Even though I prefer the Epoxy fix myself, for comparative purposes and as useful documentation, I have also posted two versions of the OFFICIAL WIS documentation relating to the fix-kit replacement procedure.
If you prefer NOT to do the epoxy fix, the FIX-KIT part number from MB is: A 220 320 25 38 for the W220 car without ABC (active body control) and without 4matic.
The fix-kit includes a new upper metal cap that includes an O-ring, and a new c-clip and brass valve, with yellow lubricant. you can see pictures at:
http://www.benzworld.org/forums/w220-s-class/1358307-leaking-front-struts-8.html#post3244659
If you decide to carry out the epoxy fix, you do NOT need the MB fix-kit.
REFILLING THE BELLOWS IS PROBABLY THE MOST IMPORTANT STEP AFTER DEALING WITH THE UPPER-PART OF THE STRUT WITH EITHER EPOXY OR THE FIX-KIT.
NOTE: of particular interest, read about the different alternatives that exist to REFILL the BELLOWS
after having carried either the fix-kit or epoxy replacement.
I have received messages from users that have damaged their front struts from improper filling, which then require replacing them entirely. Actually, if you break, tear or perforate your bellow covers, these are sold online, and you can replace any bad bellow covers, without having to replace the whole strut. If you do this, please be sure to post a thread with your procedure and any advice.
Pls read
all documentation and understand what and why you are doing stuff - if in doubt, come back, and ask here! It is important to understand that the bellow of the strut (inside the wheel wheel) has a cover with an accordion design with horizontal folds, and must be free of vertical creases or folds to ensure proper function.
If the bellow cover is damaged, this part can also be replaced, as replacement bellow covers are sold from MB and aftermarket. (not covered here).
Even though I inserted warnings in the documents, about being careful, this epoxy fix is very easy for DIY.
Don't be afraid.
Be sure to have read the full procedure, and that you have gathered all the tools and ingredients prior to starting. Also, be sure to be patient in removing, curing and testing the epoxy fix.
Lastly, in terms of tools, be sure NOT to use the one-leg jack that comes with your Benz - it is a VERY dangerous jack to use, especially for long periods, or when getting under the car, getting into the wheel well, etc.
You need to invest in TWO good pneumatic jacks, which should be about $30-$40 each at your local hardware shop, which have wide bases with wheels, and are very steady and reliable. The Epoxy fix also does not require that you remove the wheels.
Go for it, and good luck! Let us know how it went!
Regardless of the fix you decide to carry out as a DIY, I strongly recommend to read all 4 documents below prior to doing anything.
UPDATES: A few users have commented on the need to apply some sort of sealing tape/string for the brass-valve, which will sometimes leak slightly, either in the epoxy fix or the MB fix-kit, given that the brass-valve is a steel-on-steel joint. Have a look at the comments later on in this thread for more feedback and ideas.
