Old 07-09-2007, 08:07 AM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Post MAF DIY PICTORIAL: replacing/cleaning
Okay, folks, clearly I was thinking of all of you while I was on vacation.
Attached is the PDF version of the MAF R&R process.
The end of it also includes a section on cleaning the MAF sensor.
Send your checks to World Vision.
And as always, take care and enjoy the ride!
Greg
Old 07-09-2007, 08:21 AM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
great job greg.
tirona is offline   Reply With Quote
Old 07-09-2007, 10:12 AM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Lightbulb DIY UPDATE
Thanks Greg, I just added this to our DIY section.
http://www.benzworld.org/forums/w210...7-07-07-a.html
JOE55 is offline   Reply With Quote
Old 07-11-2007, 05:09 PM   #4 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(93K Miles), 2002 E320 Special Edition(112K Miles)
Greg,
This is a good one. I think I'm not the only one that cleaned the wrong part of the MAF - namely the more visible wire with the resistor on. I'll clean it out in the right place and try it again.
Kobus is offline   Reply With Quote
Old 07-12-2007, 07:33 AM   #5 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
Thanks Greg, I purchased the cleaner but I have heard if no codes come up not to touch it. So I will hold on to the cleaner with hopes never to use it but if I have to I have it on hand. What are the differences one feels when replacing or cleaning MAF?
slybydesignw210 is offline   Reply With Quote
Old 07-12-2007, 07:58 AM   #6 (permalink)
gregs210's Avatar
Hey, Sly.
Throughout the myriad MAF threads I've tried to stress that there often are no symptoms of a failing MAF beyond a trouble code or CEL (a "fault condition"). Since in my experience cleaning resolves something less than half of MAF issues, cleaning an MAF following a fault condition -- if contamination was not the cause -- will result in no difference to the driver.
However, when the MAF is dirty and that triggers the fault condition, then cleaning it will restore some amount of driveability, fuel economy, emissions control and performance.
The same holds true when the fault condition is unrelated to contamination and the MAF is replaced: the driver may sense some additional performance, throttle response, smoothness, etc.
For a good one look down in the sensor source thread, an oil driver changed his MAF and immediately noticed an improvement in driveability, smoothness, performance, etc.
As you know I recently replaced my MAF (after cleaning attempts failed to clear the code) and I've yet to notice anything. Sometimes I think it has a bit better throttle response and shifts perhaps smoother, but that's just as likely to be a psychosomatic response (basically, I changed it, so I think I notice something).
Bottom Line? You may not notice any difference after replacing or cleaning a MAF, but at least you'll know you've restored your car and it's emissions systems to proper working order. And your gaze won't be constantly drawn to the CEL.
Take care and enjoy the ride,
Greg
Old 07-12-2007, 09:51 AM   #7 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
I would like to hear success ratio in MAF cleaning. I had 2 MAFs going bad on my cars and I've got 2 more from somebody else. All of them passed visual inspection as being perfect with no signs of dirt or damage. I sprayed them all with MAF cleaner to come to ZERO success rate.
Am I in bad luck?
Edited for spelling correction
Kajtek1 is offline   Reply With Quote
Old 07-12-2007, 10:21 AM   #8 (permalink)
gregs210's Avatar
Originally Posted by Kajtek1
I would like to hear sauces ratio in MAF cleaning. I had 2 MAFs going bad on my cars and I've got 2 more from somebody else. All of them passed visual inspection as being perfect with no signs of dirt or damage. I sprayed them all with MAF cleaner to come to ZERO success rate.
Am I in bad luck?
Hey, Kajtek1.
I think you're just seeing reality. For the stories of success I hear relative to MAF cleaning, I hear far more that it doesn't do anything. For domestic brands it seems to work more often, but even then it's probably only around 50% success rate.
With all your MB's you're the perfect candidate to buy the sensor inserts. Maybe Ron at GermanStar will give you a quantity discount.
Greg
Old 07-12-2007, 11:59 AM   #9 (permalink)
OceanView's Avatar
Date registered: Sep 2004
Vehicle: 96' W210 & 07' W211
Thanks for the write up Greg.
I will try this the next time I get the CEL for MAF.
OceanView is offline   Reply With Quote
Old 08-12-2007, 09:07 AM   #10 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
My experience: the torx screw has a little protruding index at the center. I bought a set of tool from eBay, but found out that they don't work with this type of torx screw and ended up having to go to Pepboys to buy another set.
cerritos is offline   Reply With Quote
DIY pictorial window regulator replacement ashman78 W210 E-Class 112 Today 03:50 PM
DIY MAF Cleaning slk230paul R170 SLK Class 17 08-14-2007 09:17 AM
anyone have diy-info on MAF cleaning? ProV1x W210 E-Class 2 11-30-2006 05:07 PM
Hello! and interest in pictorial DIY for window regulator? ashman78 W210 E-Class 5 08-31-2005 07:00 AM
