Ive checked the body harness on my S320, (Granted engine half the size, but still can produce similar degrees of heat) and the body harness looked brand new! all the insulation was intact, and felt solid.. No worries there, but my main engine harness is crisp.. Either replacing or rebuilding mine soon.
Im just saying, in the entire history of the W140, I have NEVER heard of the body harness failing due to deterioration of the insulation. Regardless of engine size, and location.
So even though it might worth it to have a gander at the wires running to and from the coffin box, and the ones running just behind firewall.. I wouldnt look any further if those are all in great shape like they always are..
The ONLY reason the top and bottom harnesses fail is dues to the immense heat of the engine, and the fact they positioned right on the engine itself. Again, regardless of engine size.
The mirrors fail due insulation deteriorating form the mirrors being folded, positive and ground wires "short circuit" causing minor glitches, sometimes even smoke.
Unless I hear of multiple other cases and see for myself that a body harness has failed, besides strykers biased opinions and misdirections, I will not believe a single thing he says about this topic.
The W124 model also suffers from failing engine wire harness, aswel as the W202.. NONE of those cars were ever reported to have deteriorating body harness from engine heat / age..
Lets stop the hogwash, and commend a great harness rebuild!
