Hope this isn't a redundant question, but...
Here's my situation:
1) I fell victim to the same leaking front latch cylinders as so many others. I removed them (thanks for the pics on the forum!), sent them off to Dennis. (Minor update: he now charges $50 apiece, plus shipping, to rebuild. Still a deal, my opinion).
2) I did not raise the soft top during this time. Just garaged it and drove with it down.
After re-installation of cylinders, when I closed the top:
- top fully extends properly
- rebuilt front latch cylinders work fine - can hear them operate
- rear part seems to work fine, but...
- when the latches pull the rear-window portion taut, they then "back off" a bit;
- Windows then raise about two inches, then go back down.
- red light on switch flashes.
Four notes:
1) When this occurs, I can use the window switches and close both windows just fine.
2) the top lowers properly. No problems there.
3) Using its switch, the rollbar raises and lowers properly. No problems there.
4) Other than that beeping when the car starts, it seems that I can drive the car fine with the top up, I simply have to use the window switch to operate the windows.
Still, I'd just as soon have it the way it was before. If there's a code reset issue, frankly I'd rather pay the $40 then go DIY on this-- judging from the threads, that sounds like opening a can of worms - or is it simpler than it sounds? Do you think simply manually lowering the top would do it? Or raising the top?
Thanks -
Peter
