2008 EWA NET Install problem - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-01-2011, 07:26 AM Thread Starter
Date registered: Jan 2011
May be someone has an idea on this problem. I have installed the software on XP, i have reached the part were you click on the program you want to use . . . EPC or WIS. When selecting either program (EPC,WIS) Java starts to run and nothing happens, no other windows pop up and IE7 doesnt refresh with any new content. Any one has an idea of what im missing or a suggestion??
thank you
LifeenderII is offline
post #2 of 9 (permalink) Old 02-01-2011, 07:40 AM
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
Quoted: 4 Post(s)
For EPC when you click it Java will ask if you want to run, click yes. Then yes again, followed by no to the next question.....For WIS click yes then no.
SHAUNE55 is offline
post #3 of 9 (permalink) Old 02-01-2011, 11:19 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 664 Post(s)
EWA can be very fussy in regard to both Java and Adobe Reader, i.e. it doesn't always like the latest versions.
GeeS is offline
post #4 of 9 (permalink) Old 02-01-2011, 09:26 PM Thread Starter
thanks for the suggestions. now i'm getting "error while attempting login action. contact system administrator" . . . any idea on this one?
post #5 of 9 (permalink) Old 02-02-2011, 02:59 AM
SHAUNE55's Avatar
Quoted: 4 Post(s)
Mine only works with internet explorer, it won't work with google....Do you get this?
SHAUNE55 is offline
post #6 of 9 (permalink) Old 02-02-2011, 06:45 AM Thread Starter
I do get all the green check marks, but when I click on the EPC or the WIS . . . it starts intiallizing and Java loads. Soon after Java loads I get the security question, after that nothing happens or I get the "error while attempting login action. contact system administrator". Is their a service manual specific for the S550?
post #7 of 9 (permalink) Old 02-02-2011, 08:04 AM
SHAUNE55's Avatar
Quoted: 4 Post(s)
Did all discs load ok? I think I had to click the EPC update and run it and it asked for a disc that I'd already done,so I ran that disc and all was well. Open EWA and click the EPC with the spanner next to it, run that and then do the same with WIS.
SHAUNE55 is offline
post #8 of 9 (permalink) Old 02-02-2011, 08:18 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 664 Post(s)
If you have a version of Java loaded on your computer, try removing it first. If it is too new a version for your version of EWA, the install routine will fail, because the Java install will stumble at the notion of overwriting a more current version. It may not help, but it's worth a try...
GeeS is offline
post #9 of 9 (permalink) Old 08-29-2011, 08:10 PM
Date registered: Aug 2011
guys I have the same problem except for that I couldn't install the database completely
it said make sure the insert media is corret. try to re-install it or order a different package ( or something like that )
I'm working on windows 7 64bit
in addition, when I go to EWA admin tool
n click on EPC
it says The EPC net database is not installed
how to fix it ?
what can I do guys ?
Ayha88m is offline
    EWA Net Uninstall hooperdoski General Mercedes-Benz 8 09-16-2014 07:14 AM
    Ewa Net Login Problem CbIHTON General Mercedes-Benz 5 10-10-2010 01:49 PM
    Problem with EWA Net Monny General Mercedes-Benz 0 03-17-2010 02:54 AM
    EWA net does not read MAC address Minnet General Mercedes-Benz 5 12-14-2009 10:39 PM
    can someone tell me how to install epc net 2008? azrael General Mercedes-Benz 0 09-03-2008 12:41 PM
