1991 420 SEL
I currently have the red Anti Freeze coolant in my Rad
If I want to add (top off) some antifreeze, can I use the Zerex G-05 ????
G
Kingorcus - 2/25/2005 2:30 PM
G-05 is a approved anti freeze
As far as mixing I don't know
Depends on the day!
Personally I'd just look for some more dexcool in the mean time. If you're getting close to the two year mark might as well flush and use the Zerex.
Jonathan
I beleive Car & Driver did an editorial a few years ago and I've also seen a few other places that it is not suggested to mix Dexcool. I think there are differing opinions but the consensus I've gotten from it is to drain the dexcool out and flush the system THOROUGHLY and replace it with a compatible (to your system) coolant.
I could be wrong and suggest more research but for some reason I recall this. As for what to replace it with, THAT is the real question. I can't remember the particulars of it so be careful and maybe a few people here have done it also.
Basically I have the impression that it is a bad idea to mix it.
