1 - 20 of 49 Posts
Hi. I've read so many threads here on the subject of 450SLs running hot.....
I have a 77 450SL with 57,000 miles. I am the third owner.
In the cooler months, this car has had some "good days" running at about 185-195 degrees F. But it did have a tendency to get up to the 212 line, especially while driving on the freeway. At times, I feel this car is bi-polar.
I foolishly went "ALL IN" and replaced the radiator, water pump, and thermostat and saw no change whatsoever. I had a system flush don3 on the car as well.... no change.
I read several threads here on ignition timing and had Goody's Automotive look into it. I am told that the timing is set properly.
A typical drive starts just fine. Once I get to speeds of 55 MPH or higher, the temps slowly creep up from halfway between the 175 and 212 line up to the 212 line. Once the 212 is reached, the needle hardly ever goes back down, even on the freeway. This behavior is the same if the AC is on or off.
So.... New Radiator, Fan Clutch (well.... a new one only made the car sound like a Mack truck and improved NOTHING so I put the old one back on)... New water pump, new thermostat, chemical flush.....
What else should I look into?? Summer has finally arrived and the needle is going past the 212 line. I pointed an IR laser thermometer at the top of the radiator and got a reading of 220F.... I know there is a solution but I cannot seem to find it. The aux fan kicks in but does not really seem to have any effect on the temperature.
I am not loosing any coolant and there is no white smoke coming out of the exhaust so I don't think I have a blown head gasket.
Any thoughts? I am at a loss!
Thank you
The fan that makes the noise as large lorries is of a simple visco-flex and it is for the cars that do not sport the electric AUX fan at the front (AC related), all for warmer climates.
I changed the fan on my car from visco-flex (South African CKD) to thermo-visco coupled from a later 380 and the noise/cooling improved. The engine will seldom go above 90°C whilst idling and as soon as the thermo clutch engages, it drops to just below 90°C. Mostly improved the temperature swings and at idle it needs good 30min in hot weather to near to 100°C.
This was a true upgrade that required only drilling 2 holes in the new clutch hub to fit the original alu fan (new plastic one was not right for purpose and 2 of the 4 holes were mismatched but hub had provision for difference - by design).
Now back to your problem, have you ever thought to replace the thermo sensor?
I mean, the right procedure would be to use IR thermometre and check the temp but a second hand thermometer is the easier less expensive route. Perhaps also check the resistance at 100°C indicated to confirm that the indicator needle is in check.
Apparently, temp under load and in hot days is normal to come to 100°C (water boiling) but a moderate driving should bring it between 80-90°C
There's always a chance that some galleys are blocked or that the mixture runs excessively lean but IMO these all come at the bottom of the check list.
EDIT:
...and after I read your post in entirety, above suggestion is meaningless (I made it smaller)
Perhaps a good spot is to investigate correct thermostat fitting and if it does open as required. This would cause insufficient coolant bypass to the radiator. Bear in mind that this thermostat is of a change-over type, it allows coolant to circulate the engine if temp is good or low and as soon as the temp goes above the required it diverts the coolant to the radiator. Some thermostats have tiny hole to assist hot coolant transfer to the back side of the thermostat thus assisting timely and full opening of the thermostat. When I replaced this on mine, it had a metal pin that acted as a poppet valve.
At highway speeds there should not even be requirement for a fan. 60 mph unlimited air ramming through the radiator due to the forward motion of the car should completely overpower any amount of air your fan could push. In fact, at highway speeds your fan may even be an impediment to air flow.
Did you check the A/C radiator fins for blockage? Something may be restricting airflow through the radiator.
How about oil? Are you using the correct grade of oil? Is there an oil cooler?
That new fan clutch you installed that made you car sound like a truck (fan roar) happened to me as well, I too put the original back and the fan roar was gone.
If you turn on the heat does the temperature come down?
Are you using the recommended type of coolant?
Does you car roll free or is there excessive drag?
Is the fuel mixture too lean? To be honest I don't know how to check it.
Any blockage in the exhaust?
Just thinking out loud.
I know you researched this by reading threads but I fought this problem for 4 years. My car needed a rebuilt radiator with more capacity for heat dissipation. I had a custom core installed into my OE tanks. When I installed it, I noticed for the first time my cooling system had the ability to recover from a hot run in surface traffic. As soon as I got air flowing through it again, the temp would drop noticeably to a comfortable level.
The viscous fan is what cured the "stop in traffic" heat rise. These fans are annoyingly loud but they really move air well when low or no speed provides low or no airflow.
The only thing I will ever do reference a system flush is a de-oiling process followed by a citric acid flush. I've seen first hand what that removes from a system I thought was pretty clean. I am also a permanent advocate of MB coolant (blue at the moment) mixed with distilled water (arguments continue on this ingredient but my mind is made up due to results). The problem with this is, it is a DIY project because nobody in a shop in ABQ will spend the time to do this correctly.
All of it - including mistakes along the way are outlined here:
https://www.benzworld.org/forums/r-c107-sl-slc-class/2053449-cooling-system-cleaning.html
Best of luck to you on this hot topic
Thank you for the responses.
Goody's Automotive in Scottsdale set the ignition timing as well as the air/fuel mixture. They appear to be the GO TO shop for the 450SL in Arizona, so I have to assume those factors are in check.
The condenser fins are straight and so are the radiator fins.
Motor oil is 0W40. I'll check if it coasts well to determine if there is excessive drag.
I am not an engine mechanic but I think that the issue may not be a lack of cooling but one of generating more heat that what the cooling system is meant to handle (if that makes sense). Not sure if this relevant of not, but if I open the hood when the engine is hot and running, the exhaust manifolds read mid 400's F (cylinder 4 reads mid 500's).
Goody's mentioned that 212 F was "PERFECT" and "Normal" but now that we have triple digit days in AZ I find the temp readings of 220/225 ALARMINGLY high.
I just don't want to make the mistake I made earlier of replacing good parts blindly.
It does make sense and I fully agree. These early systems (that have aged) do not have enough overhead to handle Phoenix with the A/C on. Later cars had better capacity.
Thank you. How much of a difference would you say it would make?
Would going synthetic help as well?
One other thing that may be worth mentioning: I mentioned earlier that the temps start out fine and start to creep up after the car reaches 55MPH..... In terms or RPM, 55MPH equates to a little less than 2500RPM. Could the issue be related to excessive heat generation above 2500 RPM? If so, what could cause the excessive heat generation?
I just took a 1 hour drive. Ambient Temp is approximately 90 F. I never exceeded 2500 RPM and the temps stayed below the 212 line (half way between 175 and 212 MOST of the time). Needle crept up at a stop and went back down once I got going.
Discussion Starter #11
The AC definitely causes the engine to run hotter. I assumed that this would be because it is the original 42 year old compressor ( which was converted from R12 to R134 at some point) and that it probably creates too much drag when the compressor is on.
AC cooling is not a huge priority at the moment so I tend to leave it off so that it does not add to the problem. I plan to address other issues such as the AC if I ever get the engine temps under control.
Your electric fans should be turning on. you can jump the temp sensor on the engine and the fan should turn on. There is a patch to install a 1.1 ohm resistor (search for this to be sure on the resistor value) that makes the fan turn on earlier.
The is also a temp switch on the AC that will only work if your ac is properly charged.
Discussion Starter #13
Aux Fan
Funny thing that you mention the aux fan. I installed a new 212 self grounding switch. It works but it does not appear to help much. I even tried attaching a ground wire so that the fan would run when the car engine was running and I did not see any improvement. The auxiliary fan does work and I blew smoke in front of it to visually confirm it was sucking up air - It was.
Discussion Starter #14
Turning on the heat brings the temperature down a bit but the hot air that comes out is INTOLERABLY hot.
I have tried both the Mercedes Blue and the green stuff. I observed no difference between them.
The car appears to roll free. I can take the foot off the gas when going 30 MPH and it seems to want to coast just fine.
Muffler is new. The CAT/Resonator thing is the original. Hot air comes out the tailpipe but I honestly don't know how to tell if the flow is less than normal.
Not sure if it applies to your year but on mine I was seeing the same thing (high temp related to high rpm).
Setting ignition timing from factory specs (can’t even remember what that is) to 5 BTDC helped mine.
Original? I would change that before doing anything else. Or perhaps if you'd prefer to be certain that the original is bad, try disconnecting the exhaust... I know it will be noisy but if you can put up with the sound, see if it cures your running hot problem.
Before doing something drastic like replacing catalytic converters, I would confirm the cat's health with a back pressure test. Any good exhaust shop will do this for like $40-50 . No sense replacing good parts :p
I'd also go and replace the expansion tank cap (the small cap where you put in coolant). Those do go bad and can cause hot running conditions. Cheap $6 to do.
I would also confirm your hot running temperature with an IR gun on the water pump housing. Someone here once posted a before and after with a coolant gauge showing a drastic change in temperature between the two.
As stated, not all cooling gauges are the same. It's worth confirming with an external tool.
I'll risk repeating myself, above bold text confirms my thought on thermostat not doing its job of diverting sufficient coolant to the radiator (cabin heating runs on coolant straight from the engine, before thermostat). Thus increased airflow through the radiator will not help
see the coolant flow diagramme and it will make it easier to comprehend as to why thermostat can keep otherwise perfect engine hot - by not diverting enough coolant to the radiator making everything appear as functional but actually being faulty!
In depth:
https://www.startekinfo.com/StarTek/outside/11883/PROGRAM/Engine/107/M117_56/20-005.pdf
Thermostat change over (generic image):
That explains everything I have observed in my own engine (116.962). Excellent information... thank you.
During colder months my temps run around 90 but now that days are warmer the temp is running a hair under 100 (and will stay there even at highway speeds). Turning on the heater brings the temp down to about 90, maybe a little higher... now I know why. :thumbsup:
Discussion Starter #20
In depth:
Thanks. I installed a BEHR thermostat. Would a WAHLER work better?
Also, I understand there may be an auxiliary water pump (https://www.autohausaz.com/pn/0008356964OE) - Where is this component located?
1 - 20 of 49 Posts
About this Discussion
15 Participants
okyoureabeast
Mercedes-Benz Forum
Full Forum Listing
